motion active Detected motion DEVICE 03/15/2018 11:24 AM
It is currently 7:26am, but the motion sensor is showing activity 4 hours from now.
Go into the “Location” page and make sure your Zip/Lat/Long all look correct. Hit Update for good measure.
Then, go into the “Settings” page, and click on “Reboot Hub”. This will take a few minutes as it has to boot a full copy of Linux.
Hopefully afterwards, your times will be correct.
Note: I am assuming you have upgraded the Firmware already on the Hub, right?
Same problem here, applied the solution noted here… problem fixed
Good luck
Rick
Rebooting the hub did fix the issue. Thanks.
