I attempted the Device driver to clear a device schedule, etc.
I noted instead of clearing device schedules it actually added 2 - Not sure it worked the way it was expected too.
What commands did you run in the "Device" driver? And what is the name of the method (or two?) that was scheduled?
The "Get Info" command does appear to be implemented via a scheduled job (might depend on protocol; not sure if the implementation details), but I don't think I've seen this with otherrs, and this isn't one you'd need to run to "clear" things.
