Device did not turn off as expected
Came here tonight via search because once again, one of my devices didn't turn off as expected and I thought: I'll bet Hubitat has an update.
I started by going into the Google Home app and tried to turn off the device. It acted like it was going to work, then reported it was still on (correct).
Next I went to the device in Hubitat web (and yep, there's an update), tapped off, and nothing happened. Tapped the update notification, and the light turned off.
I've been seeing this behavior for a while but like others posted here I thought it was unlikely that it was related.
Quick follow up, I found another post where someone tried using the truncate command. I used it on my device tonight and will monitor.
[IP address]/hub/advanced/truncateEvents
It has been stated numerous times that the hub is not affected by the availability of an update. If it was affected your hub would have stopped working 3 days ago.
In this case it sounds like A Device had lost connection or had interference and needed a minute to reconnect.
@bobbyD We really need to close this thread and label it as false (or fact checked :rofl:).
EDITED
I'm redacting my sarcastic comment here. I was frustrated with @thebearmay but that's not the right approach. I didn't say it was directly related, I noted symptoms I've been seeing and a recent event.
@bobbyD I work in the software industry and have a background in software testing and troubleshooting. I'm happy to help dig into this further if you like.
I believe this is the log leading up to the event. Only seeing one error re SharpTools, but I don't use it any longer and removed the app this morning:
app:1652024-09-13 11:23:59.224 PMdebugSending event for HUB: update -> 2.3.9.180
app:7692024-09-13 11:21:44.637 PMtraceNo updates
app:7692024-09-13 11:21:44.179 PMtraceChecking for updates...
app:7692024-09-13 11:18:45.568 PMtraceUpdates sent (75 / 1405ms)
dev:10032024-09-13 11:18:45.566 PMinfoUpdated 3 objects (10ms)
dev:10032024-09-13 11:18:45.560 PMinfoTemperature is 72°F
dev:7722024-09-13 11:18:45.549 PMinfoUpdated 2 objects (6ms)
dev:7722024-09-13 11:18:45.545 PMinfoTemperature is 71°F
dev:7712024-09-13 11:18:45.534 PMinfoUpdated 6 objects (31ms)
app:7692024-09-13 11:18:45.491 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:18:45.381 PMinfo3 updates for 2 sensors (Great Hall, Home)
app:7692024-09-13 11:18:45.329 PMinfo6 updates for 1 thermostat (Home)
app:7692024-09-13 11:18:44.627 PMinfoRequesting ( equipmentStatus runtime extendedRuntime sensors ) for thermostat Home (313834330422) - [false]
app:7692024-09-13 11:18:44.625 PMinfoPolling 313834330422
app:7692024-09-13 11:18:44.179 PMtraceChecking for updates...
app:7692024-09-13 11:15:45.676 PMtraceUpdates sent (46 / 1474ms)
dev:10032024-09-13 11:15:45.675 PMinfoUpdated 1 object (3ms)
dev:7712024-09-13 11:15:45.660 PMinfoUpdated 5 objects (19ms)
app:7692024-09-13 11:15:45.629 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:15:45.506 PMinfo1 update for 1 sensor (Home)
app:7692024-09-13 11:15:45.454 PMinfo5 updates for 1 thermostat (Home)
app:7692024-09-13 11:15:44.696 PMinfoRequesting ( equipmentStatus runtime extendedRuntime sensors ) for thermostat Home (313834330422) - [false]
app:7692024-09-13 11:15:44.694 PMinfoPolling 313834330422
app:7692024-09-13 11:15:44.218 PMtraceChecking for updates...
dev:8992024-09-13 11:15:03.479 PMinfoWreath was turned off [digital]
app:1652024-09-13 11:15:03.309 PMerrorError sending event to SharpTools.io: status code: 401, reason phrase: Unauthorized
app:1652024-09-13 11:15:03.119 PMdebugSending event for DEVICE: 66 switch -> off
dev:662024-09-13 11:15:03.091 PMinfoStar was turned off [digital]
dev:8662024-09-13 11:15:01.046 PMinfoOutdoor-Water is off [digital]
dev:712024-09-13 11:15:00.305 PMinfoBedrooms switch is off
dev:7072024-09-13 11:15:00.218 PMinfoChristmas Lights switch is off
dev:7372024-09-13 11:15:00.099 PMinfoInside Christmas switch is off
dev:10052024-09-13 11:12:47.063 PMinfoOffice Smoke Detector carbon monoxide clear
dev:10052024-09-13 11:12:47.060 PMdebugparse:zw device: 1C, command: 7105, payload: 00 00 00 FF 02 00 00 , isMulticast: false
dev:10052024-09-13 11:12:46.766 PMinfoOffice Smoke Detector smoke clear
dev:10052024-09-13 11:12:46.759 PMdebugparse:zw device: 1C, command: 7105, payload: 00 00 00 FF 01 00 00 , isMulticast: false
dev:10052024-09-13 11:12:46.467 PMinfoOffice Smoke Detector battery is 80%
dev:10052024-09-13 11:12:46.456 PMdebugparse:zw device: 1C, command: 8003, payload: 50 , isMulticast: false
dev:10052024-09-13 11:12:46.339 PMdebugOffice Smoke Detector Device wakeup notification
dev:10052024-09-13 11:12:46.328 PMdebugparse:zw device: 1C, command: 8407, payload: , isMulticast: false
dev:10052024-09-13 11:12:46.007 PMdebugHeartbeat
dev:10052024-09-13 11:12:45.972 PMdebugparse:zw device: 1C, command: 7105, payload: 00 00 00 FF 09 05 00 , isMulticast: false
app:7692024-09-13 11:12:45.578 PMtraceUpdates sent (67 / 1404ms)
dev:10032024-09-13 11:12:45.576 PMinfoUpdated 3 objects (9ms)
dev:10032024-09-13 11:12:45.570 PMinfoTemperature is 73°F
dev:7712024-09-13 11:12:45.557 PMinfoUpdated 6 objects (33ms)
app:7692024-09-13 11:12:45.508 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:12:45.409 PMinfo2 updates for 1 sensor (Home)
app:7692024-09-13 11:12:45.357 PMinfo6 updates for 1 thermostat (Home)
app:7692024-09-13 11:12:44.665 PMinfoRequesting ( equipmentStatus runtime extendedRuntime sensors ) for thermostat Home (313834330422) - [false]
app:7692024-09-13 11:12:44.663 PMinfoPolling 313834330422
app:7692024-09-13 11:12:44.190 PMtraceChecking for updates...
app:7692024-09-13 11:09:46.043 PMtraceUpdates sent (154 / 1844ms)
dev:10032024-09-13 11:09:46.041 PMinfoUpdated 5 objects (11ms)
dev:7722024-09-13 11:09:46.020 PMinfoUpdated 5 objects (10ms)
dev:7712024-09-13 11:09:46.001 PMinfoUpdated 33 objects (101ms)
dev:7712024-09-13 11:09:45.907 PMinfoHVAC system is cooling
app:7692024-09-13 11:09:45.888 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:09:45.780 PMinfo10 updates for 2 sensors (Great Hall, Home)
app:7692024-09-13 11:09:45.727 PMinfo23 updates for 1 thermostat (Home)
app:7692024-09-13 11:09:44.732 PMinfoRequesting ( equipmentStatus settings program events audio capabilities runtime extendedRuntime sensors weather ) for thermostat Home (313834330422) - [false]
app:7692024-09-13 11:09:44.730 PMinfoPolling 313834330422
app:7692024-09-13 11:09:44.217 PMtraceChecking for updates...
app:7692024-09-13 11:06:45.579 PMtraceUpdates sent (142 / 1399ms)
dev:10032024-09-13 11:06:45.577 PMinfoUpdated 2 objects (9ms)
dev:10032024-09-13 11:06:45.569 PMinfoTemperature is 72°F
dev:7712024-09-13 11:06:45.536 PMinfoUpdated 5 objects (27ms)
app:7692024-09-13 11:06:45.435 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:06:45.364 PMinfo1 update for 1 sensor (Home)
app:7692024-09-13 11:06:45.276 PMinfo5 updates for 1 thermostat (Home)
app:7692024-09-13 11:06:44.667 PMinfoRequesting ( equipmentStatus runtime extendedRuntime sensors ) for thermostat Home (313834330422) - [false]
app:7692024-09-13 11:06:44.665 PMinfoPolling 313834330422
app:7692024-09-13 11:06:44.203 PMtraceChecking for updates...
app:1652024-09-13 11:06:07.649 PMerrorError sending event to SharpTools.io: status code: 401, reason phrase: Unauthorized
app:1652024-09-13 11:06:07.431 PMdebugSending event for DEVICE: 67 switch -> off
dev:672024-09-13 11:06:07.391 PMinfoFireplace 1 was turned off [digital]
app:1652024-09-13 11:04:57.598 PMerrorError sending event to SharpTools.io: status code: 401, reason phrase: Unauthorized
dev:982024-09-13 11:04:57.431 PMinfoAll Lights switch is off
dev:7372024-09-13 11:04:57.418 PMinfoInside Christmas switch was turned off
dev:7072024-09-13 11:04:57.409 PMinfoChristmas Lights switch was turned off
app:1652024-09-13 11:04:57.336 PMdebugSending event for DEVICE: 71 switch -> off
dev:712024-09-13 11:04:57.305 PMinfoBedrooms switch was turned off
app:7692024-09-13 11:03:45.378 PMtraceUpdates sent (1 / 1210ms)
app:7692024-09-13 11:03:45.376 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:03:45.279 PMinfo0 updates for 0 sensors
app:7692024-09-13 11:03:45.249 PMinfo0 updates for 0 thermostats
app:7692024-09-13 11:03:44.698 PMinfoRequesting ( equipmentStatus settings program events audio capabilities runtime extendedRuntime sensors ) for thermostat Home (313834330422) - [true]
app:7692024-09-13 11:03:44.695 PMinfoPolling 313834330422
app:7692024-09-13 11:03:44.184 PMtraceChecking for updates...
app:7692024-09-13 11:00:45.547 PMtraceUpdates sent (64 / 1341ms)
dev:10032024-09-13 11:00:45.545 PMinfoUpdated 1 object (5ms)
dev:7722024-09-13 11:00:45.532 PMinfoUpdated 1 object (4ms)
dev:7712024-09-13 11:00:45.519 PMinfoUpdated 11 objects (27ms)
dev:7712024-09-13 11:00:45.512 PMinfoTemperature is 72°F
app:7692024-09-13 11:00:45.481 PMinfoPolling 313834330422 completed
app:7692024-09-13 11:00:45.372 PMinfo4 updates for 2 sensors (Great Hall, Home)
app:7692024-09-13 11:00:45.325 PMinfo7 updates for 1 thermostat (Home)
app:7692024-09-13 11:00:44.369 PMinfoRequesting ( equipmentStatus settings program events audio capabilities location alerts runtime extendedRuntime sensors weather ) for thermostat Home (313834330422) - [false]
app:7692024-09-13 11:00:44.367 PMinfoPolling 313834330422 (forced)
app:7692024-09-13 11:00:44.221 PMtraceChecking for updates...
app:1652024-09-13 11:00:00.827 PMerrorError sending event to SharpTools.io: status code: 401, reason phrase: Unauthorized
app:1652024-09-13 11:00:00.459 PMdebugSending event for LOCATION: sunriseSunsetUpdated ->
app:1652024-09-13 11:00:00.440 PMdebugSending event for DEVICE: 69 switch -> off
dev:2572024-09-13 11:00:00.396 PMinfoFireplace 2 was turned off [digital]
dev:692024-09-13 11:00:00.336 PMinfoFront House switch was turned off
app:7692024-09-13 10:57:45.742 PMtraceUpdates sent (63 / 1568ms)
dev:10032024-09-13 10:57:45.740 PMinfoUpdated 2 objects (7ms)
dev:10032024-09-13 10:57:45.736 PMinfoTemperature is 72°F
dev:7722024-09-13 10:57:45.726 PMinfoUpdated 2 objects (6ms)
dev:7722024-09-13 10:57:45.722 PMinfoTemperature is 72°F
dev:7712024-09-13 10:57:45.709 PMinfoUpdated 4 objects (19ms)
app:7692024-09-13 10:57:45.678 PMinfoPolling 313834330422 completed
app:7692024-09-13 10:57:45.552 PMinfoNo sensor updates...
app:7692024-09-13 10:57:45.550 PMinfo4 updates for 1 thermostat (Home)
What is app 769? RM possibly?
While there may be a correlation here, there is no causation.
If you PM me the hub id, I can check the engineering logs. Something's up if things stop working.
And it is. It's pure coincidence that your hub was disconnected when an update was available. It's just the timing of the discovery that correlates the two facts. Please follow up with our platform engineer as mentioned above, if you'd like to narrow down the real issue.
On a lighter note..
Sort of like Pirates & Climate Change -
Hat Tip to all the CoFSM fans/believers out there...
Disclaimer: No religions where meant to be "shaded" by the above...
