Is there any way to call the device command buttons remotely? I feel like there should be an easy method, but my brain isnt working on a Monday morning. Use case: I have some garage door notifications where certain lights around the home turn red when the garage door is open. Occassionally, the garage door contact sensor doesnt report as closed. I'd like to press a button/tell google home that the garage door is indeed shut, by pressing this button below. Possible?
Also, since I capture the status of the lights as the garage door opens, I need to run the restore part of the rule - that is, I cant simply run a different rule to turn off the lights. I need the contact sensor to report as closed, so the restore happens in the initial rule.
