I am using the below app as a learning tool. Its from a list of examples by Bruce found here
My confusion starts here:
I am assuming the input statement returns a list of devices named "humidSensors"
The part that throws me is in the totaling statement :
humidSensors.each {total += it.currentHumidity}
which totals the humidity value of a number of different humidity sensors.
Specifically the capability "currentHumidity" I cannot find where the capability "currentHumidity" comes from. Its not in the Hubitat documents nor any of the many Z-Wave specs I've accumulated. It also appears nowhere else in the example program.
The app works but I'm lost has to why the seemingly undocumented capability functions.
Any help would be appreciated.
definition(
name: "Average Humidity",
namespace: "hubitat",
author: "Bruce Ravenel",
description: "Average some humidity sensors",
category: "Convenience",
iconUrl: "",
iconX2Url: "")
preferences {
page(name: "mainPage")
def mainPage() {
dynamicPage(name: "mainPage", title: " ", install: true, uninstall: true) {
section {
input "thisName", "text", title: "Name this humidity averager", submitOnChange: true
if(thisName) app.updateLabel("$thisName")
input "humidSensors", "capability.relativeHumidityMeasurement", title: "Select Humidity Sensors", submitOnChange: true, required: true, multiple: true
if(humidSensors) paragraph "Current average is ${averageHumid()}%"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
def averageDev = getChildDevice("AverageHumid_${app.id}")
if(!averageDev) averageDev = addChildDevice("hubitat", "Virtual Humidity Sensor", "AverageHumid_${app.id}", null, [label: thisName, name: thisName])
averageDev.setHumidity(averageHumid())
subscribe(humidSensors, "humidity", handler)
def averageHumid() {
def total = 0
def n = humidSensors.size()
return (total / n).toDouble().round(1)
def handler(evt) {
def avg = averageHumid()
averageDev.setHumidity(avg)
log.info "Average humidity = $avg%"
def contactHandler(evt) {
log.debug "$evt.value"
// The contactSensor capability can be either "open" or "closed"
// If it's "open", turn on the light!
// If it's "closed" turn the light off.
if (evt.value == "open") {
switch1.on();
} else if (evt.value == "closed") {
switch1.off();
