Detecting the correct model of Inovelli Red switch
I recently added a couple of Inovelli Red Z-Wave switches. When I look at each device details, HE shows them as Generic... is there a way to have the C7 correctly identify the device model? If the C7 can't, is there another way without having to go to each and remove them from the wall?
Where? As a guess, it sounds like you are talking about the driver name. That's not a problem with device identification; it's just the driver your hub (or you) assigned as indeed the best choice for a variety of devices from different manufacturers and of various models. In some cases, a more specific driver is available, and Inovelli does offer their own for all their products if you require specific features, but that is a different issue.
For your devices, the "Get Info" tab on the device detail page will show you some information. For example, you should see the "Manufacturer" listed as 798 (or 0x031E in hex), which is Inovelli's identifier. You should also see "Model" or "Id" listed there. If you have 1 (or 0x01), that's the LZW31-SN, or 2 (0x0002) for LZW30-SN (both sometimes called "gen 2"). The VZW31-SN or VZW30-SN ("third gen") are 21 (or 0x0015) or 24 (0x0018). A good place to find these is the Z-Wave JS config DB: Z-Wave JS Config DB Browser.
Holy Smokes, what an incredible resource. As much as I like Inovelli products, their descriptions and firmware versions drive me nuts.
Ok much thanks for the info on the mfg code as well as the browser... off to see if I can identify the Inovelli devices.
