[DEPRECATED] Xiaomi Drivers with Health Status and Zigbee2MQTT
There is even one more driver that you can try but seems like the problem is somewhere else, all of the other drivers should work too. Remember, after switching drivers you need to pair the sensor again to HE every time because most of these Xiaomi/Mija/Aqara sensors need specific initialization which works effectively only during the pairing procedure time window.
Are you pairing the sensor close to the hub (at a maximum distance of 1-2 meters) ?
