Nope - no PIN authentication. Send an email to Ecobee Support explaining your problem. IIRC, they can either fix your account so that apps work with 2FA on, or they can turn off 2FA on your account...
My Ecobee application has disconnected from the API Oath fail. I was on the phone with support and they stated the authentication is an old login process. That a new Log on process is needed. I cannot authenticate to the API. I don't know if anyone else is seeing this.
My code uses the published Ecobee Authentication interface, but I believe that Ecobee broke it with 2FA. If you have turned on 2FA, contact Ecobee Support and have them reset it for you (and then don't turn it back on again).
While you are talking with them, ask them for the link/pointer to the "new Log on process"...I'll implement it (if there is actually such a thing)...
Please, don't shoot the messenger. I have "some" of the information that was provided to me in an email. Side note I thought it was BS too. I did a simple test. When I click on authenticate from the Hubitat application, it points me to a URL (API, Login, Oauth) to authenticate with the Token. When I do this from an Ecobee Plus application from Alexa it has me authenticate to a different URL that is still an Ecobee login. They admitted that they have changed how they are allowing 3rd parties to access their API's. Reason I tested with Alexa is they update the application directly, not through a third party. If this wasn't true, then I would expect being sent to the same URL, but that wasn't the case.
I can log into the Ecobee main log in page without issue. It’s only when I attempt to log in from the API page, I get a log in failure. They are starting to block log ins from that entry point. In my case, the token had expired (timeout) and required a verification of credentials which failed to update the token; thus, Ecobee Suite application fails (goes offline).
FWIW, Ecobee has multiple authentication entry points, and at least 2 different APIs - the one they share with developers like me here, and the one they share with Apple Homekit (and possibly Amazon), so your test doesn't necessarily prove anything.
Further, the authentication works fine if you don't have 2FA turned on - literally more than 1500 users can attest to that (I get a log of every authenticated endpoint using my application ID).
I just checked all of the Ecobee "public" developer API pages, and they all discuss the authentication method exactly as I use it (and as described above).
Have you tried, per chance, installing the native Hubitat Ecobee Support? If it works, and mine still doesn't, then I can work with the Hubitat Team to understand what has changed. But I suspect you will experience the same as others...2FA broke 3rd party apps. See Anyone having OAuth Ecobee issues? - if so, you might want to ask Ecobee why the native Hubitat interface doesn't work...
Finally, you might TRY making sure this:
Turn off 2FA
Exit your browser
Start your browser again - make sure NOTHING logs into Ecobee
Log into your account in the browser - DON'T CLOSE or LOGOUT of that tab/window
Retry authenticating from Ecobee Suite Manager - note, it MAY not ask you to log in again
If THAT doesn't work, do the above again, but this time DON'T log into Ecobee before trying authentication. You can also try a different browser (I use Chrome and Firefox).
Turn off 2FA resolved it. Odd thing this was enabled like 2 months ago and hadn't seen any issue and no other issue with any other application into Ecobee either. I did try the native application prior to calling Ecobee because that failed too. I tried to not involve you and do what I could to resolve without going back to forum. Thank you for your help.
Contacts and switches helper question. I want to turn off the AC when two windows are open. When I select the those contact sensors the only option appears to be "Any." I could create a rule with a virtual switch but I would guess there are others that also want to turn the AC on and off when they open up some specific combination of windows and doors for outside ventilation.
You're the first person to ask for that, actually. It gets real complicated trying to handle all the possible combinations of switches and contact sensors, so I decided long ago to just leave it to be handled by Rule Manager (or WebCoRE) automation.
Hey Barry. On my iPad, I’m unable to select my thermostat under the Smart Circulation helper (update: its happening under many of these helpers). Please see attached when drop down is selected:
Update #2: changed the thermostat name on the thermostat from ‘Ecobee Home” to “Thermostat” the reauthorized again and now drop down selections are working.
Barry—is there a way to set the “Smart Switches & Vents Helper” to be more specific per room?
For example, I have an Ecobee Sensor called “Nursery Sensor” for my nursery room which should control/be more specific to a “Nursery Keen Vent.” So the Sensor and the vent exist in one room together.
Then, I have another sensor called “Master Bedroom Sensor” which controls two vents in my master bedroom.
Currently, I only see that I can add sensors and vents so the helper seems more generalized and maybe I’m wrong, but I think being able to specify which rooms smart vents and their sensors belong to would provide more efficiency versus a “whole home comfort” strategy?
Easy-peasy: Just create a separate instance of the Smart Vents Helper for each room, each using the appropriate sensor and the relevant vent(s)...as I have done below:
