Any chance you can point me at exatxtly what I should purchase? Are all node MCU created equal?
What sort of wire leads should I purchase? Anything else that may be needed?
@cwwilson08 These are the ones I use
Bread board.
FTDI USB UART
Jumper Pin assortment M-M / M-F / F-F (The breadboard comes with some but these are better...
Ty sir. All ordered.
@cwwilson08 make ABSOLUTLY sure that the slider on the UART is at 3.3v If you hook it up at 5v whatever you have conected is a gonner.
@JulesT I got a new bulb in today. Got it flashed and Can get White Red and Blue. No Green...
I have tried putting PWM3 everywhere else but no go. When I flashed the bulb it was plashing green so I know the color works..... Any thoughts?
Update. I have RGBW mapped out now
Gosund RGB Bulb A19
D2 GPIO4 - PWM1 (37) White
D6 GPIO12 - PWM2 (38) Red
D7 GPIO13 - PWM4 (40) Blue
D5 GPIO14 - PWM3 (39) Green
Looks like each bulb is different
What are the requirements of your device handler?
Yeah. Looking at the the Tuya dev thing... they've basically got an app builder - you tell it what things are on what GPIO pins, and it configures the app accordingly. Seems a bit arse-about-face, but what I do know?; )
The requirements are pretty non-existent, to be honest - As long as you can go to the console and get color and 'white ' to work, then install the device handler... and point it at the IP address of the bulb. That should do the trick.
The good thing about it, basically, is that it's up to the tasmota firmware to know how to make the bulb do it's thing
Hopefully that'll work. If not... let me know what it's up to, and I'll try to fix it up.
-- Jules
Hi Damon.
No app... just a device handler. No discovery, either - so you'll have to add them by hand and then configure them.
Install the following DH:
Then add device... select the driver... and configure it. Set the DNI to something that'll end up being unique - tasmota_attic_lamp_3 or whatever
-- Jules
@JulesT It does absolutely nothing for me? I installed the handler. Added the device and configured the device. Is there something I have to do in the DH?
I have configured the ip in the device
This is the log
dev:3692019-01-26 01:23:54.302 am errororg.apache.http.conn.HttpHostConnectException: Connect to null:80 [null/127.0.0.1] failed: Connection refused (Connection refused) on line 282 (on)
dev:3692019-01-26 01:23:54.267 am debughttp://null:80/ax?c1=Power%20On
dev:3692019-01-26 01:23:54.241 am debugon()
dev:3692019-01-26 01:23:53.538 am errororg.apache.http.conn.HttpHostConnectException: Connect to null:80 [null/127.0.0.1] failed: Connection refused (Connection refused) on line 282 (off)
dev:3692019-01-26 01:23:53.392 am debughttp://null:80/ax?c1=Power%20Off
Did you enter your IP in the driver?
OK. It's not got the IP address for some reason.
Let me create a new device at my end, and check if my code was buggered up
-- Jules
OK. It's definately not your fault, Damon.
I moved some bits around to make it less hacky, and part of that was butchering out some more sophisticated preferences code that was unnecessary. Apparently my much simpler replacement is a load of arse
Gimme 2 mins, and I'll get a fix bodged in.
-- Jules
Hi Damon.
OK. I'm an idiot. 'ip' and 'ipAddress' aren't the same variable - who'd have thought it?
My fault - because I was bodging the driver about - the IP address was set right in the state of the device I was working on anyway.
I've re-uploaded it - fetch the changed driver from the same place, it should magically start working. If it doesn't, re-set the IP Address, and all should be well.
Sorry about that, and thanks for your patience.
-- Jules
Everything should be here today. I've done some reading and think I'm ready. The socket I have seems to be no way of opening without destroying it. So I am putting that A-side for now.
Hopefully can ressurect the strip and get a driver going. Then flash the other.
@JulesT Thank you!!
ok I now have it controlling the bulb. Here is the issues:
Set Color hue:97 sat:100 level:89 Bulb goes white instead of red
Set Color hue:27 sat:97 level:89 Bulb goes "yellowish white" instead of green
Set Color hue:62 sat:100 level:100 Bulb goes "blueish white" instead of blue
So Set Color isn't working for me
Setting color Temp turns my light to green no matter the setting
Set Level Does Nothing
Set Hue 30 is RED
Set Hue 50 is Pink
Set Hue 60 is Blue
So, I'm very grateful for the control of these bulbs at least I can turn them on and off again. Thank you!
Hopefully the color settings can be fixed too
Hmmm. looks like you've got the settings wrong, then.
If you go to the console on the tasmota web interface, and type 'white 100' - what colour do you get?
Similarly, if you do 'rgbcolor' commands on the web console, do the following do what you expect:
rgbcolor ff0000 - should be red.
rgbcolor 00ff00 - should be green.
rgbcolor 0000ff - should be blue.
If those aren't right, then you've got the GPIO settings wrong.
Tasmota assumes the following, I think, from playing with it:
PWM1 - Red
PWM2 - Green
PWM3 - Blue
PWM4 - White
I'd start with - do a 'white 100' - and whatever color it is - you should set PWM4 to the GPIO pin on your current setup that corresponds to the color above. Repeat for other colours until it all makes sense.
Of course... if the console does the right thing, and the driver is wrong, then it's my fault, and I'll have to work out a way to look at it
-- Jules
@JulesT Ok so I did have my pins configured wrong. You have given the BEST explanation that I have seen on this subject. Thank you.
Now only one more issue to fix.... I cant Dim. Other than that it's ready to go.
Adjusted the code to fix dimming.
* Copyright 2016 Eric Maycock & Jules Taplin
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Sonoff Wifi Switch
* Author: Eric Maycock (erocm123)
* Date: 2016-06-02
import groovy.json.JsonSlurper
import groovy.util.XmlSlurper
metadata {
definition (name: "Tasmota RGBW Bulb", namespace: "uk.org.ourhouse", author: "Jules Taplin") {
//capability "Actuator"
capability "Switch"
//capability "Refresh"
capability "ColorControl"
capability "ColorMode"
capability "ColorTemperature"
capability "Light"
capability "Switch"
capability "SwitchLevel"
//capability "Sensor"
//capability "Configuration"
//capability "Health Check"
//command "reboot"
attribute "needUpdate", "string"
attribute "uptime", "string"
attribute "ip", "string"
attribute "level", "number" //added by damondins
simulator {
preferences {
input description: "Once you change values on this page, the corner of the \"configuration\" icon will change orange until all configuration parameters are updated.", title: "Settings", displayDuringSetup: false, type: "paragraph", element: "paragraph"
generate_preferences(configuration_model())
preferences { section("Sonoff Host") {
input(name: "ipAddress", type: "string", title: "IP Address", displayDuringSetup: true, required: true)
//tileAttribute ("device.level", key: "SLIDER_CONTROL") {
// attributeState "level", action:"setLevel"
tiles (scale: 2){
multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", backgroundColor:"#00a0dc", icon: "st.switches.switch.on", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", backgroundColor:"#ffffff", icon: "st.switches.switch.off", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", backgroundColor:"#00a0dc", icon: "st.switches.switch.off", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", backgroundColor:"#ffffff", icon: "st.switches.switch.on", nextState:"turningOn"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("ip", "ip", width: 2, height: 1) {
state "ip", label:'IP Address\r\n${currentValue}'
valueTile("uptime", "uptime", width: 2, height: 1) {
state "uptime", label:'Uptime ${currentValue}'
main(["switch"])
details(["switch",
"refresh","configure","reboot",
"ip", "uptime"])
def installed() {
log.debug "installed()"
configure()
def configure() {
logging("configure()", 1)
def cmds = []
cmds = update_needed_settings()
cmds << getAction("/info")
if (cmds != []) cmds
def updated()
logging("updated()", 1)
def cmds = []
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "lan", hubHardwareId: device.hub.hardwareID])
sendEvent(name:"needUpdate", value: device.currentValue("needUpdate"), displayed:false, isStateChange: true)
private def logging(message, level) {
if (logLevel != "0"){
switch (logLevel) {
case "1":
if (level > 1)
log.debug "$message"
break
case "99":
break
def parse(description) {
def events = []
def msg = parseLanMessage(description)
def descMap = parseDescriptionAsMap(description)
def body
if (descMap["mac"] != null && (!state.mac || state.mac != descMap["mac"])) {
log.debug "Mac address of device found ${descMap["mac"]}"
state.mac = descMap["mac"]
if (state.mac != null && state.dni != state.mac) state.dni = setDeviceNetworkId(state.mac)
if (descMap["body"]) body = new String(descMap["body"].decodeBase64())
if (body && body != "") {
if(body.startsWith("{") || body.startsWith("[")) {
def slurper = new JsonSlurper()
def result = slurper.parseText(body)
log.debug "result: ${result}"
if (result.containsKey("type")) {
if (result.type == "configuration")
events << update_current_properties(result)
if (result.containsKey("power")) {
events << createEvent(name: "switch", value: result.power)
if (result.containsKey("uptime")) {
events << createEvent(name: "uptime", value: result.uptime, displayed: false)
if (result.containsKey("deviceType")) {
state.type = result.deviceType
} else {
//log.debug "Response is not JSON: $body"
if (!device.currentValue("ip") || (device.currentValue("ip") != getDataValue("ip"))) events << createEvent(name: 'ip', value: getDataValue("ip"))
return events
def parseDescriptionAsMap(description) {
description.split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
if (nameAndValue.length == 2) map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
else map += [(nameAndValue[0].trim()):""]
def on() {
log.debug "on()"
def cmds = []
sendEvent(name: "switch", value: "on");
cmds << getAction("Power%20On")
return cmds
def off() {
log.debug "off()"
def cmds = []
sendEvent(name: "switch", value: "off");
cmds << getAction("Power%20Off")
return cmds
def refresh() {
log.debug "refresh()"
def cmds = []
cmds << getAction("info")
cmds << getAction("status")
return cmds
def ping() {
log.debug "ping()"
refresh()
def setColorTemperature(value)
state.colorMode = "CT"
sendEvent(name: "colorMode", value: "CT");
setLevel(state.level,0)
def setLevel(value) {
sendEvent(name: "level", value: value);
cmds << getAction("Dimmer%20" + value);
def setColor(value) {
log.debug "HSVColor = "+value
if (value instanceof Map) {
def h = value.containsKey("hue") ? value.hue : null
def s = value.containsKey("saturation") ? value.saturation : null
def b = value.containsKey("level") ? value.level : null
setHsb(h, s, b)
} else {
log.warn "Invalid argument for setColor: ${value}"
def setHsb(h,s,b)
log.debug("setHsb - ${h},${s},${b}")
myh = h*4
if( myh > 360 ) { myh = 360 }
hsbcmd = "hsbcolor+${myh},${s},${b}"
log.debug "Cmd = ${hsbcmd}"
state.hue = h
state.saturation = s
state.level = b
state.colorMode = "RGB"
sendEvent(name: "hue", value: h);
sendEvent(name: "saturation", value: s);
sendEvent(name: "level", value: b);
sendEvent(name: "colorMode", value: "RGB");
getAction(hsbcmd)
def setHue(h)
setHsb(h,state.saturation,state.level)
def setLevel(v,duration)
if(state.colorMode == "RGB") {
setHsb(state.hue,state.saturation,v)
else
state.level = v
sendEvent(name: "level", value: v);
getAction("white+${v}")
def setSaturation(s)
setHsb(state.hue,s,state.level)
private getAction(uri){
updateDNI()
def userpass
def response
if(password != null && password != "")
userpass = encodeCredentials("admin", password)
def headers = getHeader(userpass)
def params = [
uri: "http://${getHostAddress()}/ax?c1=${uri}",
headers: headers
log.debug "http://${getHostAddress()}/ax?c1=${uri}"
httpGet(params) { resp ->
response = resp.data
return parseResponse(response)
private postAction(uri, data){
updateDNI()
def userpass
def response
def params = [
uri: "http://${getHostAddress()}${uri}",
headers: headers
httpPost(params) { resp ->
private setDeviceNetworkId(ip, port = null){
def myDNI
if (port == null) {
myDNI = ip
} else {
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
myDNI = "$iphex:$porthex"
log.debug "Device Network Id set to ${myDNI}"
return myDNI
private updateDNI() {
if (state.dni != null && state.dni != "" && device.deviceNetworkId != state.dni) {
device.deviceNetworkId = state.dni
private getHostAddress() {
if (override == "true" && ipAddress != null && ipAddress != ""){
return "${ipAddress}:80"
else if(getDeviceDataByName("ipAddress") && getDeviceDataByName("port")){
return "${getDeviceDataByName("ipAddress")}:${getDeviceDataByName("port")}"
}else{
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
return hexport
private encodeCredentials(username, password){
def userpassascii = "${username}:${password}"
def userpass = "Basic " + userpassascii.bytes.encodeBase64().toString()
return userpass
private getHeader(userpass = null){
def headers = [:]
headers.put("Host", getHostAddress())
headers.put("Content-Type", "application/x-www-form-urlencoded")
if (userpass != null)
headers.put("Authorization", userpass)
return headers
def reboot() {
log.debug "reboot()"
def uri = "/reboot"
getAction(uri)
def sync(ip, port) {
def existingIp = getDataValue("ip")
def existingPort = getDataValue("port")
if (ip && ip != existingIp) {
updateDataValue("ip", ip)
sendEvent(name: 'ip', value: ip)
if (port && port != existingPort) {
updateDataValue("port", port)
def generate_preferences(configuration_model)
def configuration = new XmlSlurper().parseText(configuration_model)
configuration.Value.each
if(it.@hidden != "true" && it.@disabled != "true"){
switch(it.@type)
case ["number"]:
input "${it.@index}", "number",
title:"${it.@label}\n" + "${it.Help}",
range: "${it.@min}..${it.@max}",
defaultValue: "${it.@value}",
displayDuringSetup: "${it.@displayDuringSetup}"
break
case "list":
def items = []
it.Item.each { items << ["${it.@value}":"${it.@label}"] }
input "${it.@index}", "enum",
displayDuringSetup: "${it.@displayDuringSetup}",
options: items
break
case ["password"]:
input "${it.@index}", "password",
break
case "decimal":
input "${it.@index}", "decimal",
break
case "boolean":
input "${it.@index}", "boolean",
break
/* Code has elements from other community source @CyrilPeponnet (Z-Wave Parameter Sync). */
def update_current_properties(cmd)
def currentProperties = state.currentProperties ?: [:]
currentProperties."${cmd.name}" = cmd.value
if (settings."${cmd.name}" != null)
if (settings."${cmd.name}".toString() == cmd.value)
sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
else
sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
state.currentProperties = currentProperties
def update_needed_settings()
def cmds = []
def configuration = new XmlSlurper().parseText(configuration_model())
def isUpdateNeeded = "NO"
cmds << getAction("/configSet?name=haip&value=${device.hub.getDataValue("localIP")}")
cmds << getAction("/configSet?name=haport&value=${device.hub.getDataValue("localSrvPortTCP")}")
if ("${it.@setting_type}" == "lan" && it.@disabled != "true"){
if (currentProperties."${it.@index}" == null)
if (it.@setonly == "true"){
logging("Setting ${it.@index} will be updated to ${it.@value}", 2)
cmds << getAction("/configSet?name=${it.@index}&value=${it.@value}")
} else {
if (it.@index == "externaltype") {
if(state.type != "Sonoff S20") {
isUpdateNeeded = "YES"
logging("Current value of setting ${it.@index} is unknown", 2)
cmds << getAction("/configGet?name=${it.@index}")
} else {
log.debug "Sonoff S20 does not support externatype configuration"
} else {
else if ((settings."${it.@index}" != null || it.@hidden == "true") && currentProperties."${it.@index}" != (settings."${it.@index}"? settings."${it.@index}".toString() : "${it.@value}"))
logging("Setting ${it.@index} will be updated to ${settings."${it.@index}"}", 2)
cmds << getAction("/configSet?name=${it.@index}&value=${settings."${it.@index}"}")
sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
return cmds
def parseResponse(description) {
//log.debug "Parsing: ${description}"
return // DISABLED FOR NOW!
def events = []
def result = description
if (result != []){
events.each {
sendEvent(it)
return events
def configuration_model()
<configuration>
<Value type="text" index="ip" label="IP Address" setting_type="preference"></Value>
<Value type="list" index="logLevel" label="Debug Logging Level?" value="0" setting_type="preference" fw="">
<Help>
</Help>
<Item label="None" value="0" />
<Item label="Reports" value="1" />
<Item label="All" value="99" />
</Value>
</configuration>
}`Preformatted text`
Well guys. I got close. But in the end fail. I managed to flash my strip. Connected to it once over IP. Undid all my soldering plugged into mains and nothing. Looks like I mangled original connections
Lol I think I have to tap out.
Oh... what a bastard. Sorry to hear that.
Ah well. Your dedication to trying can't be faulted!
-- Jules
