A little lost. New to tasmota, so a lot to learn still. Thanks to markus for letting me know that I could flash the wemos mini to control ws2812b strips in hubitat (waiting on my strips to arrive to try).
Now I am moving onto operating the garage door with another wemos mini I have lying around... Yes I know there are other threads on doing this, but none of them are thorough enough for me to not get a little lost.
SO I have made one module as a "relay" which I have working. I have a rule to make it turn off after 1 second so when I buy the ssr tomorrow I can make it simulate a momentary button push.
Now I want to use reed switches to determine what state the roller door is in (rather than a samsung multi sensor). However for some reason if I choose a switch (see my screenshots) the status never shows in the main page of the device and only the "relay" status shows. Which means it doesn't show as a child device in hubitat.
Exactly how you need to connect this depends on the type of reed switch you are using. With a 3-wire reed switch where 1 wire goes to the pin you set to be a Switch, 1 goes to 3.3v and the third one to ground there is no need for a resistor. For a 2-wire one you probably need a resistor:
Setting a pin to Switch doesn't give you an easy way to have a state, if you set your Reed switch pin to Switch1 you also need to set an unused pin to Relay1. Then run, for Switch1, the command "switchmode1 1" in the console. For Switch2 it would be "switchmode2 1".
Hope this makes sense? If you control the relay opening/closing the garage door from the same Tasmota device or want to control the relay on another Tasmota directly over wifi without involving/relying on HE that is also possible using Rules directly on Tasmota.
I was thinking to leave this reply here, but will use the other thread for new questions.
Thanks. The reed switch wiring makes sense as I've done that previously for anither esp project.
However just to confirm. So in tasmota I set a pin as switch2. I set another pin as relay2. I then run the console command as you mentioned. This then means that when switch2 pin go high, then relay2 appears as high? Is that how it works? So for every switch you need to use two pin allocations, however I could use the output for something if it was useful? If I use switch3 do I also need to use relay3, as the numbers link them together?
Or I monitor for messages thaf say when a sensor goes high or low but that's a but more learning to do? Or is this totally wrong as well?
Seems this is good reading for me huh. I guess I looked at switches slightly different coming from using only arduino ide on standard esp8266 firmwares in the past. Tasmota is more focused on switches that directly operate a relay on the same device.. So this is why they are likely this way in tasmota firmware.
Thanks heaps. I've managed to get something in order inside the house this evening.. Reed switch changes switch 2. Switch 1 toggled turns the digital pin high/low. Started writing rules to change the status of switches on my dashboard to match the status of the reed switch.. So ready to install into the garage door opener once I get the solid state relay and the wifes permission to spend time outside in the garage
On another note, I just realised that the new and updated xioami/aqara drivers I am using are yours as well. So without your efforts, well my hubitat just wouldn't be the same. Thanks.
Hello friends, I managed to add a Tuya IR Bridge (UFO-01) in the tasmota, in Smartthings after I added it in the tasmota I was able to create a virtual air conditioning control, I wanted to know if I can do something like this here
I am not sure which the correct driver to use and how to use this bridge ir tuya
I have Mitsubishi mini splits and was able to set up IR blasters using tazmota IR and Webcore. I setup my blasters in each room and then used the virtual thermostat in Hubitat attached to a webcore piston that sends an http get to my IR blasters. Let me know if this is along the lines of what you are trying to setup and I can get you more info on my setup.
@markus, I need your help, I am trying to use the IR with tasmota in the same way that I used in Smartthings with WebCORE, but when doing the same in Hubitat the command is not sent
I am one of those trying to get rid from smartthings and coming here. I have on ST a SmartApp that talk to tasmota and so, the IR-blasters I have are controlling my AC and TVs. Today that and the Sonoff RF bridge (also tasmota) are the only things I dont know how to migrate to HE. Not big deal since the rest of my home are pretty much switches (tasmota) and zigbee/zwave devices.
What I would like is to understand how to use the IR and RF as I use on ST. I also use webcore and had it installed on HE. Can you help me into those?
