Then , which version are you at now? If you're above v7.1.2, best let some more experienced people try my firmware I released the binaries for a few minutes ago. Tell me which version you're at and I'll advice from there. Usually you will have to go to tasmota-minimal and then to tasmota-hubitat, but it depends on which version you are at right now. Regardless, before upgrading, the reset-functions described in the link above can be crucial. Since it is a new device you have no settings to lose anyway.
Tasmota v7.2.0 and v8.1.0 for Hubitat has been released with binaries, please try them, but be careful and be ready to have to recover through TTL... See this post and the first post. I've tested all of these binaries and upgraded back and forth between 7.2.0 and 8.1.0 via the minimal builds over the device webpage without issues, but who knows, more testing would be good.
Hey Markus! Thanks for your prompt reply!
okay...let's start from fresh here...
I'm now going to start flashing a "new" smartplug that's currently still bind to cloud.
the following is steps that I will take from reading your posts: (by following the youtube digiblur instruction to flash)
Download tasmota-minimal.bin (v7.1.2) and winscp it to files folder within my pi
I've found it risky to do Tuya Convert with a Minimal build since it leaves parts of the flash memory untouched and this can result in a corrupted config and an unresponsive device, you could be lucky and it works, you may also not be... Tasmota-basic (from v7.2.0 Tasmota-Lite) is usually a safer alternative.
If you use the minimal build and not the basic build, then once you get to the device webpage you can use my binary you're linking to, but run "reset 5" in the console first. If you use Tasmota-basic with Tuya Convert, then first go to MY released tasmota-minimal, then install tasmota-hubitat.
Hi Markus, thanks for the link for fast device recovery! you're a life saviour! So instead of flashing another plug, I thought I picked up where I left off with this.
After following the device recovery process, I then found SSID of that plug (tasmota-xxxx).
Connected to it and found that the plug was flashed with 7.2 tasmota, from here, I went and flashed it with your minimalist 7.1.2 then hubitat 7.1.2.
I then was able to enable hue bridge emulation which then followed by putting my hubitat IP and the port for the hub/smartthings section.
2 further pains:(unfortunately)
my plug doesn't seems to be delivering power anymore. the button is unresponsive. does that mean that it is now properly bricked?
I am now able to detect the device from my hubitat, but when I tried to add it, it came up with an error --> Error: Device type 'Sonoff POW Wifi Switch' in namespace 'erocm123' not found
Edited: within the configuration module, it is set as SonOff Basic (1). not sure if this is correct or not. and the toggle on the page doesn't seems to be doing anything either.
All drivers have been updated with capabilities according to the latest best practices, this should not break anything, but if it does, please report it.
The Generic Switch/Plug and Switch/Light are now setting the capabilites correctly for Alexa, please try them and tell me of other drivers where this may be broken if you find any.
This exists as a hidden feature in the Generic Switch/Plug and Generic Switch/Light drivers now. I did add a try-catch statement, just in case.
No, it just means the configuration isn't right yet, the template must be set correctly. Exactly which device is it? Aoycocr X10S? For the correct template (not needed if I have driver for that SPECIFIC device), check here.
Use my version of Tasmota Connect, not the one from erocm123. Then use either a Generic driver with/without Power Monitor depending on your needs. If you have Aoycocr X10S, then I have a driver specific for that one.
There's a guide here.
No, that was wrong, updated the links, good catch, too many posts and too many links tonight... I've looked at that, it is not a process I'll be even attempting for a long time, not sure I will ever even try after having talked with some of them. It's an amazingly well written piece of code, but adding something like this to it is not very welcomed. So I'll keep my version maintained separately.
No worries, I'm attempting to setup a local OTA repo with all versions so I can upgrade more easily. If I'm on 7.1.6 and put an OTA url of 7.2.0, it never seems to upgrade. Do I need to go to minimal first even if OTA? If you don't know, no worries. Again, thanks for your work on this and all the versions AND support on the drivers!
No it's actually Aoycocr U3S. I've followed that link and found the template.
I've managed to set everything accept for the that I can see on mine is ADC0
this has now thankfully made the on / on button to be responsive again as well as the toggle on the webui.
sorry, not really following this one. when you meant Tasmota Connect, you do mean the bin files that I used to flash this plug with, correct? If yes, then yes I have used yours.
then I added the app code as instructed on the page.
Sorry again as I'm a complete noob here.
From what I understand you need to have tasmota-minimal.bin on the OTA server, I remember seeing something in the code about it falling back to minimal first if the actual firmware is too large.
Should probably get this up and running myself once I decide to switch over all my devices to 8.1...
No, the issue is the driver, if you only installed the PM driver, make sure to select that one when installing the device. The other things does not affect.You might have to add the “generic wifi switch/plug driver”, but it shouldn’t be needed. The App is not something I’ve put much effort into making user friendly, it really needs quite a bit of work... One of these days the App will get an update...
Switch would be the generic one, there’s other depending on what you think suits the situation. Best is searching the forum and exploring on your own:) There are others that know this part much better than I.
You’re welcome!
I’m not really certain since I’m rather new here and have not really read any such things, I’ve mostly gone for finding specific information when I’ve needed it. With that said, there’s driver examples released by Hubitat on their Github, there’s also the Development docs and for more I’m sure the community in this forum have a lot to offer. Look around some more and I’m sure you’ll find the info you need
