I've added two scenes that existed on Philips hue. This is a modification to the Lighting effects child app. When you create a lighting effect, just pick all the color settings for Artic or Sunset.
- **************** Lighting Effects Child ****************
- Design Usage:
- Designed to make static holiday lights dim or flicker randomly.
- Randomly change colors on color change bulbs, completely separate or all together.
- Slowly dim a set of dimmable devices, great for night time routines.
- Slowly raise a set of dimmable devices, great for morning routines.
- Setup a loop to continually raise and lower dimmable devices.
- Create a spooky, sparkly or party effect.
- Copyright 2018-2020 @BPTWorld - Bryan Turcotte
- This App is free. If you like and use this app, please be sure to mention it on the Hubitat forums! Thanks.
- Remember...I am not a programmer, everything I do takes a lot of time and research!
- Donations are never necessary but always appreciated. Donations to support development efforts are accepted via:
- Paypal at: PayPal.Me
- Unless noted in the code, ALL code contained within this app is mine. You are free to change, ripout, copy, modify or
- otherwise use the code in anyway you want. This is a hobby, I'm more than happy to share what I have learned and help
- the community grow. Have FUN with it!
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
- Apache License, Version 2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- If modifying this project, please keep the above header intact and add your comments/credits below - Thank you! - @BPTWorld
- App and Driver updates can be found at GitHub - bptworld/Hubitat: Apps for use with Hubitat Elevation
- Changes:
- 2.0.5 - 11/08/20 - Adjustments
- 2.0.4 - 08/28/20 - Added App Control options
- 2.0.3 - 08/16/20 - Added Light Level to Fast_Color_Changing & Slow_Color_Changing, other changes
- 2.0.2 - 04/27/20 - Cosmetic changes
- 2.0.1 - 04/12/20 - Major changes
- 1.0.0 - 10/01/18 - Initial release. This is where it all started for me. By looking at other people work and piecing things
- together. Learning by example! Next up was Googling everything I could find, reading, trying... reading more, trying again.
- Before long, BPTWorld apps was born. Didn't know you were going to get a history lesson today, did you! lol.
import groovy.time.TimeCategory
import java.text.SimpleDateFormat
def setVersion(){
state.name = "Lighting Effects"
state.version = "2.0.5"
definition(
name: "Lighting Effects Child",
namespace: "BPTWorld",
author: "Bryan Turcotte",
description: "Create a spooky, sparkly or party effect.",
category: "",
parent: "BPTWorld:Lighting Effects",
iconUrl: "",
iconX2Url: "",
iconX3Url: "",
importUrl: "https://raw.githubusercontent.com/bptworld/Hubitat/master/Apps/Lighting%20Effects/LE%20Child.groovy",
preferences {
page(name: "pageConfig")
def pageConfig() {
dynamicPage(name: "", title: "", install: true, uninstall: true) {
display()
section("Instructions:", hideable: true, hidden: true) {
paragraph "Lighting Effects is designed to work with Hue devices. While other brands may work, nothing is guaranteed. If not using Hue devices, you can try turning on 'Enable Hue in degrees (0-360)' for each device used with this app."
paragraph "Fast Dimming:"
paragraph "For each Child App, multiple devices can be selected. Each device will run sequential, Device 1, then Device 2, Back to device 1, then device 2..etc."
paragraph "To create a random effect, put each device in a separate Child App, using the same switch to turn them on."
paragraph "Fast Color Changing:"
paragraph "Designed for color changing bulbs. This section can control lights individually, or all together within the same child app. Used to change colors between 5 sec and 5 minutes."
paragraph "Slow Color Changing:"
paragraph "Designed for color changing bulbs. This section can control lights individually, or all together within the same child app. Used to change colors between 5 minutes and 3 hours."
paragraph "Slow Off, On and Loop:"
paragraph "Designed to slowly raise or lower any dimmable device. Great for morning or night routines. Also has the ability to setup a loop to continually raise and lower a dimmable device. Note: The dimming is not smooth but rather done in steps."
paragraph "Important:"
paragraph "Be sure to turn off 'Enable descriptionText logging' for each device. Can create a LOT of log entries!"
paragraph "Very Important:"
paragraph "Remember that the more devices you add and the faster you send commands, the more you're flooding the network. If you see 'normal' devices not responded as quickly or not at all, be sure to scale back the lighting effects."
section(getFormat("header-green", "${getImage("Blank")}"+" Setup")) {
input "triggerMode", "enum", title: "Select Lights Type", submitOnChange: true, options: ["Fast_Dimmer","Fast_Color_Changing","Slow_Color_Changing", "Slow_Off","Slow_On","Slow_Loop"], required: true, multiple: false
paragraph "Note: When changing Light Type, all selections will be deleted."
if(state.previousTrigger == null) state.previousTrigger = triggerMode
log.warn "previousTrigger: ${state.previousTrigger} - triggerMode: ${triggerMode}"
if(state.previousTrigger == triggerMode) {
// all good
} else {
app.removeSetting("dimmers")
app.removeSetting("sleepytime")
app.removeSetting("lights")
app.removeSetting("sleepytime2")
app.removeSetting("sleepPattern")
app.removeSetting("seperate")
app.removeSetting("pattern")
app.removeSetting("colorSelection")
app.removeSetting("lightLevel")
app.removeSetting("minutes")
app.removeSetting("targetLevelLow")
app.removeSetting("targetLevelHigh")
if(triggerMode == "Fast_Dimmer"){
section(getFormat("header-green", "${getImage("Blank")}"+" Used to change colors between 5 sec and 5 minutes")) {
input "dimmers", "capability.switchLevel", title: "Select Dimmable Lights", required: false, multiple: true
input "sleepytime", "number", title: "Enter the delay between actions - Big number = Slow, Small number = Fast" , required: true, defaultValue: 6000
if(triggerMode == "Fast_Color_Changing"){
section(getFormat("header-green", "${getImage("Blank")}"+" Select your options")) {
input "lights", "capability.colorControl", title: "Select Color Changing Bulbs", required: false, multiple:true
input "sleepytime2", "number", title: "Enter the delay between actions in seconds (range 5 to 300)" , required: true, defaultValue: 300, range: '5..300'
input "sleepPattern", "enum", title: "Delay constant or random", defaultValue: "constant", options: ["constant","random"], required: true, multiple: false
input "seperate", "enum", title: "Cycle each light individually or all together", defaultValue: "individual", options: ["individual","combined"], required: true, multiple: false
input "pattern", "enum", title: "Cycle or Randomize each color", defaultValue: "randomize", options: ["randomize","cycle"], required: true, multiple: false
input "colorSelection", "enum", title: "Choose your colors", options: [
["Soft White":"Soft White - Default"],
["White":"White - Concentrate"],
["Daylight":"Daylight - Energize"],
["Warm White":"Warm White - Relax"],
"Red","Green","Blue","Yellow","Orange","Purple","Pink", "Artic1", "Artic2", "Artic3", "Sunset1", "Sunset2", "Sunset3", "Sunset4"
], required: true, multiple: true
input "lightLevel", "number", title: "Lighting Level (1 to 99)", required: true, multiple: false, defaultValue: 99, range: '1..99'
if(triggerMode == "Slow_Color_Changing"){
section(getFormat("header-green", "${getImage("Blank")}"+" Used to change colors between 5 minutes and 3 hours")) {
input "sleepytime2", "number", title: "Enter the delay between actions in minutes (range 5 to 180)" , required: true, defaultValue: 60, range: '5..180'
if(triggerMode == "Slow_On"){
input "dimmers", "capability.switchLevel", title: "Select dimmer devices to slowly raise", required: true, multiple: true
input "minutes", "number", title: "Takes how many minutes to raise (1 to 60)", required: true, multiple: false, defaultValue:5, range: '1..60'
input "targetLevelHigh", "number", title: "Target Level (1 to 99)", required: true, multiple: false, defaultValue: 99, range: '1..99'
state.tMode = "Slow_On"
if(triggerMode == "Slow_Off"){
input "dimmers", "capability.switchLevel", title: "Select dimmer devices to slowly dim", required: true, multiple: true
input "minutes", "number", title: "Takes how many minutes to dim (1 to 60)", required: true, multiple: false, defaultValue:5, range: '1..60'
input "targetLevelLow", "number", title: "Target Level (1 to 99)", required: true, multiple: false, defaultValue: 1, range: '1..99'
state.tMode = "Slow_Off"
if(triggerMode == "Slow_Loop"){
input "minutes", "number", title: "Takes how many minutes per dim or raise (1 to 60)", required: true, multiple: false, defaultValue:5, range: '1..60'
input "targetLevelHigh", "number", title: "Target Level - High(1 to 99)", required: true, multiple: false, defaultValue: 99, range: '1..99'
input "targetLevelLow", "number", title: "Target Level - Low(1 to 99)", required: true, multiple: false, defaultValue: 1, range: '1..99'
state.tMode = "Slow_Loop"
section(getFormat("header-green", "${getImage("Blank")}"+" Activate the Dimming/Color Changing when this switch is on")) {
input "switches", "capability.switch", title: "Switch", required: true, multiple: false
section(getFormat("header-green", "${getImage("Blank")}"+" App Control")) {
input "pauseApp", "bool", title: "Pause App", defaultValue:false, submitOnChange:true
if(pauseApp) {
if(app.label) {
if(!app.label.contains(" (Paused)")) {
app.updateLabel(app.label + " (Paused)")
} else {
if(app.label) {
app.updateLabel(app.label - " (Paused)")
paragraph "This app can be enabled/disabled by using a switch. The switch can also be used to enable/disable several apps at the same time."
input "disableSwitch", "capability.switch", title: "Switch Device(s) to Enable / Disable this app", submitOnChange:true, required:false, multiple:true
section(getFormat("header-green", "${getImage("Blank")}"+" General")) {
label title: "Enter a name for this automation", required: false
input "logEnable", "bool", defaultValue: false, title: "Enable Debug Logging", description: "debugging", submitOnChange:true
display2()
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
if(logEnable) log.debug "Updated with settings: ${settings}"
unsubscribe()
unschedule()
if(logEnable) runIn(3600, logsOff)
initialize()
def initialize() {
checkEnableHandler()
if(pauseApp || state.eSwitch) {
log.info "${app.label} is Paused or Disabled"
} else {
if(triggerMode == "Fast_Dimmer"){subscribe(switches, "switch", fastDimmerHandler)}
subscribe(switches, "switch", changeHandler)
state.colorOffset=0
subscribe(switches, "switch", slowChangeHandler)
state.colorOffset=0
if(triggerMode == "Slow_On"){subscribe(switches, "switch", slowonHandler)}
if(triggerMode == "Slow_Off"){subscribe(switches, "switch", slowoffHandler)}
if(triggerMode == "Slow_Loop"){subscribe(switches, "switch", slowonHandler)}
def fastDimmerHandler(evt) {
} else {
if(logEnable) log.debug "In fastDimmerHandler (${state.version})"
if(switches.currentValue("switch") == "on") {
if(triggerMode == "Dimmer") {
for (dimmer in dimmers) {
def lowLevel= Math.abs(new Random().nextInt() % 20) + 30
dimmer.setLevel(lowLevel)
sTime = Math.abs(new Random().nextInt() % sleepytime)
pauseExecution(sTime)
def upLevel= Math.abs(new Random().nextInt() % 75) + 24
dimmer.setLevel(upLevel)
runIn(10, fastDimmerHandler)
} else if(switches.currentValue("switch") == "off") {
dimmers.off()
unschedule()
def changeHandler(evt) { // Modified code from ST - Kristopher Kubicki
} else {
if(logEnable) log.debug "In changeHandler (${state.version})"
if(logEnable) log.debug "In changeHandler - Color Selection = ${colorSelection}"
lights.on()
if(logEnable) log.debug " - - - - - - - - - - In changeHandler - triggerMode = ${triggerMode}"
for (numberoflights in lights) {
if(logEnable) log.debug " - - - - - - - - - - sleepPattern = ${sleepPattern}"
if(sleepPattern == "random"){
slTime = Math.abs(new Random().nextInt() % sleepytime2)
if(logEnable) log.debug " - - - - - - - - - - In random - slTime: ${slTime}"
} else{
slTime = sleepytime2
if(logEnable) log.debug " - - - - - - - - - - In constant - slTime: ${slTime}"
def colors =
colors = colorSelection
if(logEnable) log.debug "In changeHandler - Colors: ${colors}"
def offLights = lights.findAll { light -> light.currentSwitch == "off" }
if(logEnable) log.debug "In changeHandler - offLights: ${offLights}"
def onLights = lights.findAll { light -> light.currentSwitch == "on" }
if(logEnable) log.debug "In changeHandler - onLights: ${onLights}"
def numberon = onLights.size()
def numcolors = colors.size()
if(logEnable) log.debug "In changeHandler - pattern = ${pattern}"
if (pattern == 'randomize') {
randOffset = Math.abs(new Random().nextInt()%numcolors)
if(logEnable) log.debug "In changeHandler - Pattern: ${pattern} - Offset: ${randOffset}"
if (seperate == 'combined') {
sendcolor(onLights,colors[randOffset])
} else {
for(def i=0;i<numberon;i++) {
sendcolor(onLights[i],colors[(randOffset + i) % numcolors])
} else if (pattern == 'cycle') {
if (onLights.size() > 0) {
if (state.colorOffset >= numcolors) {
state.colorOffset = 0
sendcolor(onLights,colors[state.colorOffset])
if(logEnable) log.debug "In changeHandler - cycle-combined - onLighgts: ${onLights}, Colors: ${colors[state.colorOffset]}"
} else {
sendcolor(onLights[i],colors[(state.colorOffset + i) % numcolors])
if(logEnable) log.debug "In changeHandler - cycle-randomize - onLighgts: ${onLights[i]}, Colors: ${colors[(state.colorOffset + i) % numcolors]}"
state.colorOffset = state.colorOffset + 1
if(logEnable) log.debug "In changeHandler - slTime: ${slTime}"
runIn(slTime, changeHandler)
lights.off()
unschedule()
def slowChangeHandler(evt) { // Modified code from ST - Kristopher Kubicki
} else {
if(logEnable) log.debug "In slowChangeHandler (${state.version})"
if(logEnable) log.debug "In slowChangeHandler - Color Selection: ${colorSelection}"
lights.on()
slpTime = (sleepytime2*60)
def colors =
if(logEnable) log.debug "In slowChangeHandler - Colors: ${colors}"
def offLights = lights.findAll { light -> light.currentSwitch == "off"}
if(logEnable) log.debug "In slowChangeHandler - offLights: ${offLights}"
def onLights = lights.findAll { light -> light.currentSwitch == "on"}
if(logEnable) log.debug "In slowChangeHandler - onLights: ${onLights}"
if(logEnable) log.debug "In slowChangeHandler - pattern: ${pattern}"
if(logEnable) log.debug "In slowChangeHandler - Pattern: ${pattern} - Offset: ${randOffset}"
} else {
if (state.colorOffset >= numcolors ) {
if(logEnable) log.debug "In slowChangeHandler - cycle-combined - onLighgts: ${onLights}, Colors: ${colors[state.colorOffset]}"
} else {
if(logEnable) log.debug "In slowChangeHandler - cycle-randomize - onLighgts: ${onLights[i]}, Colors: ${colors[(state.colorOffset + i) % numcolors]}"
if(logEnable) log.debug "In slowChangeHandler - slpTime: ${slpTime}"
runIn(slpTime, slowChangeHandler)
} else if(switches.currentValue("switch") == "off"){
lights.off()
unschedule()
def slowonHandler(evt) { // Modified code from @Bravenel
} else {
if(logEnable) log.debug "In slowonHandler (${state.version})"
if(dimmers[0].currentSwitch == "off") {
dimmers.setLevel(0)
state.currentLevel = 0
} else{
state.currentLevel = dimmers[0].currentLevel
if(minutes == 0) return
seconds = minutes * 6
state.dimStep = targetLevelHigh / seconds
state.dimLevel = state.currentLevel
if(logEnable) log.debug "In slowonHandler - tMode: ${state.tMode} - Current Level: ${state.currentLevel} - dimStep: ${state.dimStep} - targetLevel: ${targetLevelHigh}"
dimStepUp()
def dimStepUp() { // Modified code from @Bravenel
} else {
if(logEnable) log.debug "In dimStepUp (${state.version})"
if(state.currentLevel < targetLevelHigh) {
state.dimLevel = state.dimLevel + state.dimStep
if(state.dimLevel > targetLevelHigh) {state.dimLevel = targetLevelHigh}
state.currentLevel = state.dimLevel.toInteger()
dimmers.setLevel(state.currentLevel)
if(logEnable) log.debug "dimStepUp - tMode: ${state.tMode} - Current Level: ${state.currentLevel} - dimStep: ${state.dimStep} - targetLevel: ${targetLevelHigh}"
runIn(10,dimStepUp)
} else{
if(logEnable) log.debug "dimStepUp - tMode = ${state.tMode}"
if(state.tMode == "Slow_Loop") {
runIn(1,slowoffHandler)
} else{
switches.off()
if(logEnable) log.debug "dimStepUp - tMode: ${state.tMode} - Current Level: ${state.currentLevel} - targetLevel: ${targetLevelHigh} - Target Level Reached"
} else{
if(logEnable) log.debug "Current Level: ${state.currentLevel} - Control Switch turned Off"
def slowoffHandler(evt) { // Modified code from @Bravenel
} else {
if(logEnable) log.debug "In slowoffHandler (${state.version})"
dimmers.setLevel(99)
state.currentLevel = 99
} else{
state.dimStep1 = (targetLevelLow / seconds) * 100
if(logEnable) log.debug "In slowoffHandler - tMode: ${state.tMode} - Current Level: ${state.currentLevel} - dimStep: ${state.dimStep} - targetLevel: ${targetLevelLow}"
dimStepDown()
def dimStepDown() { // Modified code from @Bravenel
} else {
if(logEnable) log.debug "In dimStepDown (${state.version})"
if(state.currentLevel > targetLevelLow) {
state.dimStep = state.dimStep1
state.dimLevel = state.dimLevel - state.dimStep
if(state.dimLevel < targetLevelLow) {state.dimLevel = targetLevelLow}
if(logEnable) log.debug "In dimStepDown - tMode: ${state.tMode} - Current Level: ${state.currentLevel} - dimStep: ${state.dimStep} - targetLevel: ${targetLevelLow}"
runIn(10,dimStepDown)
} else{
if(logEnable) log.debug "In dimStepDown - tMode = ${state.tMode}"
runIn(1,slowonHandler)
} else {
switches.off()
if(logEnable) log.debug "In dimStepDown - tMode: ${state.tMode} - Current Level: ${state.currentLevel} - targetLevel: ${targetLevelLow} - Target Level Reached"
} else{
def sendcolor(lights,color) {
if(logEnable) log.debug "In sendcolor (${state.version})"
def hueColor = 0
def saturation = 100
if(lightLevel) onLevel = lightLevel
switch(color) {
case "White":
hueColor = 52
saturation = 19
break;
case "Daylight":
hueColor = 53
saturation = 91
break;
case "Soft White":
hueColor = 23
saturation = 56
break;
case "Warm White":
hueColor = 20
saturation = 80
break;
case "Blue":
hueColor = 70
break;
case "Green":
hueColor = 39
break;
case "Yellow":
hueColor = 25
break;
case "Orange":
hueColor = 10
break;
case "Purple":
hueColor = 75
break;
case "Pink":
hueColor = 83
break;
case "Red":
hueColor = 100
break;
case "Artic1":
hueColor = 48
saturation = 100
break;
case "Artic2":
hueColor = 58
saturation = 100
break;
case "Artic3":
hueColor = 77
saturation = 70
break;
case "Sunset1":
hueColor = 9
saturation = 80
break;
case "Sunset2":
hueColor = 95
saturation = 76
break;
case "Sunset3":
hueColor = 77
saturation = 66
break;
case "Sunset4":
hueColor = 10
saturation = 76
break;
def value = [switch: "on", hue: hueColor, saturation: saturation, level: onLevel as Integer ?: 100]
lights*.setColor(value)
if(logEnable) log.debug "In sendcolor - Setting lights: ${lights} - value: ${value}"
// ********** Normal Stuff **********
def logsOff() {
log.info "${app.label} - Debug logging auto disabled"
app?.updateSetting("logEnable",[value:"false",type:"bool"])
def checkEnableHandler() {
state.eSwitch = false
if(disableSwitch) {
if(logEnable) log.debug "In checkEnableHandler - disableSwitch: ${disableSwitch}"
disableSwitch.each { it ->
eSwitch = it.currentValue("switch")
if(eSwitch == "on") { state.eSwitch = true }
def setDefaults(){
if(logEnable) log.debug "Initialising defaults..."
if(logEnable == null){logEnable = false}
def getImage(type) { // Modified from @Stephack Code
def loc = "<img src=https://raw.githubusercontent.com/bptworld/Hubitat/master/:/images/"
if(type == "Blank") return "${loc}blank.png height=40 width=5}>"
if(type == "checkMarkGreen") return "${loc}checkMarkGreen2.png height=30 width=30>"
if(type == "optionsGreen") return "${loc}options-green.png height=30 width=30>"
if(type == "optionsRed") return "${loc}options-red.png height=30 width=30>"
if(type == "instructions") return "${loc}instructions.png height=30 width=30>"
if(type == "logo") return "${loc}logo.png height=60>"
def getFormat(type, myText="") { // Modified from @Stephack Code
if(type == "header-green") return "
${myText}
if(type == "line") return "
if(type == "title") return "${myText}
def display() {
setVersion()
getHeaderAndFooter()
theName = app.label
if(theName == null || theName == "") theName = "New Child App"
section (getFormat("title", "${getImage("logo")}" + " ${state.name} - ${theName}")) {
paragraph "${state.headerMessage}"
paragraph getFormat("line")
def display2() {
section() {
paragraph "
${state.name} - ${state.version}
paragraph "${state.footerMessage}"
def getHeaderAndFooter() {
timeSinceNewHeaders()
if(state.totalHours > 4) {
if(logEnable) log.debug "In getHeaderAndFooter (${state.version})"
def params = [
uri: "https://raw.githubusercontent.com/bptworld/Hubitat/master/info.json",
requestContentType: "application/json",
contentType: "application/json",
timeout: 30
try {
def result = null
httpGet(params) { resp ->
state.headerMessage = resp.data.headerMessage
state.footerMessage = resp.data.footerMessage
catch (e) { }
if(state.headerMessage == null) state.headerMessage = "<div style='color:#1A77C9'><a href='https://github.com/bptworld/Hubitat' target='_blank'>BPTWorld Apps and Drivers</a></div>"
if(state.footerMessage == null) state.footerMessage = "<div style='color:#1A77C9;text-align:center'>BPTWorld Apps and Drivers<br><a href='https://github.com/bptworld/Hubitat' target='_blank'>Donations are never necessary but always appreciated!</a><br><a href='https://paypal.me/bptworld' target='_blank'><b>Paypal</b></a></div>"
def timeSinceNewHeaders() {
if(state.previous == null) {
prev = new Date()
} else {
SimpleDateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd'T'HH:mm:ssZ")
prev = dateFormat.parse("${state.previous}".replace("+00:00","+0000"))
def now = new Date()
use(TimeCategory) {
state.dur = now - prev
state.days = state.dur.days
state.hours = state.dur.hours
state.totalHours = (state.days * 24) + state.hours
state.previous = now
//if(logEnable) log.warn "In checkHoursSince - totalHours: ${state.totalHours}"
