Test code preliminary results:
I was able to create effects for Aurora and Rainbow and call them easily. Lightning gave me a little bit more trouble but that effect has trouble on a good day in the native app. Here are the logs from creating/calling effects. I have successfully deleted effects by their name but that is not reflected in these logs. I definitely want to provide deeper testing this weekend and I'm excited about the possibilities but I wanted to get some initial logs and feed back in your hands
dev:2592021-09-03 17:35:14.440 info[Light Strip / 6.3.3 / Office Desk LEDs]| updateBulbData: Status = [power:on, mode:normal, level:100, colorTemp:0, hue:59, sat:100]
dev:2592021-09-03 17:35:14.425 debug[Light Strip / 6.3.3 / Office Desk LEDs]| setRgbData: hue = 59 // highRes = false
dev:2592021-09-03 17:35:14.414 debug[Light Strip / 6.3.3 / Office Desk LEDs]| updateBulbData: [on_off:1, mode:normal, hue:213, saturation:100, color_temp:0, brightness:100]
dev:2592021-09-03 17:35:14.364 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"system":{"get_sysinfo":{}}}
dev:2592021-09-03 17:35:14.351 debug[Light Strip / 6.3.3 / Office Desk LEDs]| refresh
dev:2592021-09-03 17:35:12.357 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 4. Setting Comms Error.
dev:2592021-09-03 17:35:12.334 warn[Light Strip / 6.3.3 / Office Desk LEDs]| setCommsError: Four consecutive errors. Setting commsError to true. ErrorData = null. Polled all IPs on segment 192.168.25.
dev:2592021-09-03 17:35:05.331 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:35:03.305 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:35:01.276 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 3. Retransmitting command, try = 3
dev:2592021-09-03 17:35:01.262 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:59.236 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:57.229 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 2. Retransmitting command, try = 2
dev:2592021-09-03 17:34:57.216 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:55.189 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:53.181 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 1. Retransmitting command, try = 1
dev:2592021-09-03 17:34:53.167 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:51.143 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:51.139 trace{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}
dev:2592021-09-03 17:34:51.136 trace[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Lightning.
dev:2592021-09-03 17:34:51.133 debug[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Lightning.
dev:2592021-09-03 17:34:48.931 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: null || [custom:0, id:izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT, brightness:100, name:Rainbow, segments:[0], expansion_strategy:1, enable:0, type:sequence, duration:0, transition:1500, direction:1, spread:12, repeat_times:0, sequence:[[0, 100, 100], [100, 100, 100], [200, 100, 100], [300, 100, 100]], err_code:0]
dev:2592021-09-03 17:34:48.877 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: null || [custom:0, id:izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT, brightness:100, name:Rainbow, segments:[0], expansion_strategy:1, enable:0, type:sequence, duration:0, transition:1500, direction:1, spread:12, repeat_times:0, sequence:[[0, 100, 100], [100, 100, 100], [200, 100, 100], [300, 100, 100]], err_code:0]
dev:2592021-09-03 17:34:48.831 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:34:48.828 info[Light Strip / 6.3.3 / Office Desk LEDs]| updateBulbData: Status = [power:on, mode:normal, level:100, colorTemp:0, hue:59, sat:100]
dev:2592021-09-03 17:34:48.825 info[Light Strip / 6.3.3 / Office Desk LEDs]| setRgbData: Color name is Azure.
dev:2592021-09-03 17:34:48.792 info[Light Strip / 6.3.3 / Office Desk LEDs]| setRgbData: Color Mode is RGB
dev:2592021-09-03 17:34:48.748 debug[Light Strip / 6.3.3 / Office Desk LEDs]| setRgbData: hue = 59 // highRes = false
dev:2592021-09-03 17:34:48.741 debug[Light Strip / 6.3.3 / Office Desk LEDs]| updateBulbData: [on_off:1, mode:normal, groups:[[0, 15, 213, 100, 100, 0]], err_code:0]
dev:2592021-09-03 17:34:48.190 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lightStrip":{"set_light_state":{"ignore_default":1,"on_off":1,"brightness":100,"hue":213,"saturation":100,"color_temp":0,"transition_period":0}}}
dev:2592021-09-03 17:34:48.187 debug[Light Strip / 6.3.3 / Office Desk LEDs]| setColor: [saturation:100, hue:59, level:100] // 0
dev:2592021-09-03 17:34:36.942 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 5.
dev:2592021-09-03 17:34:36.939 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:34.922 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"system":{"get_sysinfo":{}}}
dev:2592021-09-03 17:34:34.911 debug[Light Strip / 6.3.3 / Office Desk LEDs]| refresh
dev:2592021-09-03 17:34:32.907 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 4. Setting Comms Error.
dev:2592021-09-03 17:34:32.891 warn[Light Strip / 6.3.3 / Office Desk LEDs]| setCommsError: Four consecutive errors. Setting commsError to true. ErrorData = null. Polled all IPs on segment 192.168.25.
dev:2592021-09-03 17:34:25.470 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:23.436 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:21.428 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 3. Retransmitting command, try = 3
dev:2592021-09-03 17:34:21.415 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:19.379 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:17.372 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 2. Retransmitting command, try = 2
dev:2592021-09-03 17:34:17.359 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:15.317 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:13.310 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 1. Retransmitting command, try = 1
dev:2592021-09-03 17:34:13.297 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:34:11.256 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}},"context":{"source":""}}
dev:2592021-09-03 17:34:11.244 trace{"random_seed":600,"fadeoff":150,"init_states":[[240,30,100]],"custom":0,"expansion_strategy":1,"err_code":0,"hue_range":[240,240],"type":"random","transition":50,"segments":[7,20,23,32,34,35,49,65,66,74,80],"duration":0,"brightness":100,"brightness_range":[90,100],"enable":1,"saturation_range":[10,11],"backgrounds":[[200,100,100],[200,50,10],[210,10,50],[240,10,0]],"name":"Lightning","id":"ojqpUUxdGHoIugGPknrUcRoyJiItsjuE"}
dev:2592021-09-03 17:34:11.240 trace[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Lightning.
dev:2592021-09-03 17:34:11.237 debug[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Lightning.
dev:2592021-09-03 17:33:57.909 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: null || [custom:0, id:izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT, brightness:100, name:Rainbow, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:1, spread:12, repeat_times:0, sequence:[[0, 100, 100], [100, 100, 100], [200, 100, 100], [300, 100, 100]], err_code:0]
dev:2592021-09-03 17:33:57.905 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: null || [custom:0, id:izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT, brightness:100, name:Rainbow, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:1, spread:12, repeat_times:0, sequence:[[0, 100, 100], [100, 100, 100], [200, 100, 100], [300, 100, 100]], err_code:0]
dev:2592021-09-03 17:33:57.872 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:33:56.953 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"custom":0,"expansion_strategy":1,"err_code":0,"type":"sequence","transition":1500,"repeat_times":0,"segments":[0],"spread":12,"duration":0,"sequence":[[0,100,100],[100,100,100],[200,100,100],[300,100,100]],"brightness":100,"enable":1,"name":"Rainbow","id":"izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT","direction":1}},"context":{"source":""}}
dev:2592021-09-03 17:33:54.926 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 1. Retransmitting command, try = 1
dev:2592021-09-03 17:33:54.912 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:33:52.879 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"custom":0,"expansion_strategy":1,"err_code":0,"type":"sequence","transition":1500,"repeat_times":0,"segments":[0],"spread":12,"duration":0,"sequence":[[0,100,100],[100,100,100],[200,100,100],[300,100,100]],"brightness":100,"enable":1,"name":"Rainbow","id":"izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT","direction":1}},"context":{"source":""}}
dev:2592021-09-03 17:33:52.867 trace{"custom":0,"expansion_strategy":1,"err_code":0,"type":"sequence","transition":1500,"repeat_times":0,"segments":[0],"spread":12,"duration":0,"sequence":[[0,100,100],[100,100,100],[200,100,100],[300,100,100]],"brightness":100,"enable":1,"name":"Rainbow","id":"izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT","direction":1}
dev:2592021-09-03 17:33:52.841 trace[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Rainbow.
dev:2592021-09-03 17:33:52.838 debug[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Rainbow.
dev:2592021-09-03 17:33:42.440 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: null || [custom:0, id:xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu, brightness:100, name:Aurora, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:4, spread:7, repeat_times:0, sequence:[[120, 100, 100], [240, 100, 100], [260, 100, 100], [280, 100, 100]], err_code:0]
dev:2592021-09-03 17:33:42.435 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: null || [custom:0, id:xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu, brightness:100, name:Aurora, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:4, spread:7, repeat_times:0, sequence:[[120, 100, 100], [240, 100, 100], [260, 100, 100], [280, 100, 100]], err_code:0]
dev:2592021-09-03 17:33:42.403 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:33:41.479 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"custom":0,"expansion_strategy":1,"err_code":0,"type":"sequence","transition":1500,"repeat_times":0,"segments":[0],"spread":7,"duration":0,"sequence":[[120,100,100],[240,100,100],[260,100,100],[280,100,100]],"brightness":100,"enable":1,"name":"Aurora","id":"xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu","direction":4}},"context":{"source":""}}
dev:2592021-09-03 17:33:39.472 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 1. Retransmitting command, try = 1
dev:2592021-09-03 17:33:39.459 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:33:37.424 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"set_lighting_effect":{"custom":0,"expansion_strategy":1,"err_code":0,"type":"sequence","transition":1500,"repeat_times":0,"segments":[0],"spread":7,"duration":0,"sequence":[[120,100,100],[240,100,100],[260,100,100],[280,100,100]],"brightness":100,"enable":1,"name":"Aurora","id":"xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu","direction":4}},"context":{"source":""}}
dev:2592021-09-03 17:33:37.410 trace{"custom":0,"expansion_strategy":1,"err_code":0,"type":"sequence","transition":1500,"repeat_times":0,"segments":[0],"spread":7,"duration":0,"sequence":[[120,100,100],[240,100,100],[260,100,100],[280,100,100]],"brightness":100,"enable":1,"name":"Aurora","id":"xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu","direction":4}
dev:2592021-09-03 17:33:37.405 trace[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Aurora.
dev:2592021-09-03 17:33:37.402 debug[Light Strip / 6.3.3 / Office Desk LEDs]| effectSet: Aurora.
dev:2592021-09-03 17:33:25.054 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffece: Lightning added to effectPresets
dev:2592021-09-03 17:33:25.052 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffece: Lightning added to effectPresets
dev:2592021-09-03 17:33:25.042 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: true || [custom:0, id:ojqpUUxdGHoIugGPknrUcRoyJiItsjuE, brightness:100, name:Lightning, segments:[7, 20, 23, 32, 34, 35, 49, 65, 66, 74, 80], expansion_strategy:1, enable:1, type:random, hue_range:[240, 240], saturation_range:[10, 11], brightness_range:[90, 100], duration:0, transition:50, init_states:[[240, 30, 100]], fadeoff:150, random_seed:600, backgrounds:[[200, 100, 100], [200, 50, 10], [210, 10, 50], [240, 10, 0]], err_code:0]
dev:2592021-09-03 17:33:25.038 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: true || [custom:0, id:ojqpUUxdGHoIugGPknrUcRoyJiItsjuE, brightness:100, name:Lightning, segments:[7, 20, 23, 32, 34, 35, 49, 65, 66, 74, 80], expansion_strategy:1, enable:1, type:random, hue_range:[240, 240], saturation_range:[10, 11], brightness_range:[90, 100], duration:0, transition:50, init_states:[[240, 30, 100]], fadeoff:150, random_seed:600, backgrounds:[[200, 100, 100], [200, 50, 10], [210, 10, 50], [240, 10, 0]], err_code:0]
dev:2592021-09-03 17:33:24.971 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:33:08.780 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffece: Rainbow added to effectPresets
dev:2592021-09-03 17:33:08.777 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffece: Rainbow added to effectPresets
dev:2592021-09-03 17:33:08.774 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: true || [custom:0, id:izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT, brightness:100, name:Rainbow, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:1, spread:12, repeat_times:0, sequence:[[0, 100, 100], [100, 100, 100], [200, 100, 100], [300, 100, 100]], err_code:0]
dev:2592021-09-03 17:33:08.771 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: true || [custom:0, id:izRhLCQNcDzIKdpMPqSTtBMuAIoreAuT, brightness:100, name:Rainbow, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:1, spread:12, repeat_times:0, sequence:[[0, 100, 100], [100, 100, 100], [200, 100, 100], [300, 100, 100]], err_code:0]
dev:2592021-09-03 17:33:08.723 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:33:06.719 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 2. Retransmitting command, try = 2
dev:2592021-09-03 17:33:06.708 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:33:04.691 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:33:02.689 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 1. Retransmitting command, try = 1
dev:2592021-09-03 17:33:02.676 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:33:00.659 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:32:34.332 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffece: Aurora added to effectPresets
dev:2592021-09-03 17:32:34.329 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffece: Aurora added to effectPresets
dev:2592021-09-03 17:32:34.324 trace[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: true || [custom:0, id:xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu, brightness:100, name:Aurora, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:4, spread:7, repeat_times:0, sequence:[[120, 100, 100], [240, 100, 100], [260, 100, 100], [280, 100, 100]], err_code:0]
dev:2592021-09-03 17:32:34.321 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parseEffect: true || [custom:0, id:xqUxDhbAhNLqulcuRMyPBmVGyTOyEMEu, brightness:100, name:Aurora, segments:[0], expansion_strategy:1, enable:1, type:sequence, duration:0, transition:1500, direction:4, spread:7, repeat_times:0, sequence:[[120, 100, 100], [240, 100, 100], [260, 100, 100], [280, 100, 100]], err_code:0]
dev:2592021-09-03 17:32:34.283 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
dev:2592021-09-03 17:32:32.279 debug[Light Strip / 6.3.3 / Office Desk LEDs]| handleCommsError: Count: 1. Retransmitting command, try = 1
dev:2592021-09-03 17:32:32.268 debug[Light Strip / 6.3.3 / Office Desk LEDs]| parse: LAN Error = LAN_TYPE_UDPCLIENT_ERROR]
dev:2592021-09-03 17:32:30.252 debug[Light Strip / 6.3.3 / Office Desk LEDs]| sendLanCmd: command = {"smartlife.iot.lighting_effect":{"get_lighting_effect":{}}}
