Very BIG Thank YOU for this LocalThings HA Integration! I successfully added my Samsung Microwave and everything is working just fine plus the control is 100% local. I am very happy to ger rid from very last cloud-based integrations. Now my setup is true 100% local. The Microwave integration was a cloud-based but it was not critical. I was ready to cut a wires and add a Zigbee Relays for controlling light and fan. I am glad I was too lazy to rush with implementing this work around. LocalThings did solve a problem without physically modifying a Microwave. And Thank You for the HubiThings Replica. Despite it is a cloud-based integration it was a solution for the Microwave integration.
Sounds good any idea if the samsung tv's will be added to the list? Or is it for appliances only.
There is already a very complete HA solution for Samsung TVs. The only thing I found tricky is power-on, which has always been hit or miss depending on the TV. I ended up using SharpTools so I didn’t have to mess with Wake-on-LAN, but HA documents how to handle it if your TV supports it.
Seeing a lot of these errors in the last couple days, this example is a Frame TV but the healthstatus error is occurring on others as well.
**app:859**2026-10-15 8:25:56.285 am warn HubiThings Replica smartHealthHandler() error: java.lang.SecurityException: Computed device command 'setHealthStatusValue' is not allowed : [deviceId:626c1035-ae76-c030-647f-aadcdb9f41de, lastUpdatedDate:2026-10-15T12:12:49.066Z, state:ONLINE]
**app:859**2026-10-15 8:25:56.068 am error java.lang.SecurityException: Computed device command 'setMuteValue' is not allowed on line 3037 (method asyncHttpGetCallback)
On latest version via HPM, attempted a repair but no improvement. Any thoughts?
I can barely read that GIF, but it looks like an error that was being worked on in the last Hubitat beta. What firmware version are you running on your hub?
Also, I’ve seen reports of SmartThings API errors in the Home Assistant forums, so you might be running into issues on that side as well.
I’m barely using HubiThings anymore. With the potential move to pay-to-play for both the SmartThings API and Hubitat Cloud Extend, which HubiThings relies on, I’ve pretty much moved on...this was fun to build and learn, but not monthly money fun. ![]()
Edited above post to the actual text.
Version 2.5.2.135, I did see posts regarding other issues after upgrading. Maybe I will just rollback to see if that resolves.
Understood, using as long as I can. Nice to have but not necessary for just my appliances at this point.
HubiThings Replica: A Thank You and a Farewell
With mixed emotions, I am announcing that the HubiThings Replica application will be discontinued. After SmartThings changes access to its cloud API, the app will no longer function unless its owner is on a paid API plan. SmartThings says existing integrations can continue during the transition period, but API access may be paused after December 15, 2026 for apps without a paid plan. SmartThings announcement has the details.
HubiThings Replica uses the SmartThings API_ONLY 'app' API version, which the new 'smartapp' API does not yet support. If SmartThings adds support later, updating this application would require a paid Developer Plan. I do not plan to pay for that migration, so HubiThings Replica will be sunset when access to the current API ends.
If you are looking for alternatives:
Hubitat Mira is the suggested option for local communication. It does require a SmartThings Hub.
For appliance support Home Assistant LocalThings is a suggested option.
For cloud mirroring of devices, SmartTools is a suggested option with its rules capabilities, though it requires a paid subscription.
A huge thank-you to everyone who has supported HubiThings Replica over the years. I’ve appreciated the help, ideas, bug reports, and patience. SmartThings has a long and storied tradition of December surprises, and after ten years of being entertained by them, I’m officially unsubscribing from the show.
Thanks for being part of the journey.
You might want to update the thread title to include “deprecated”
Sad to see, I want to thank you for the great app I enjoyed using it in the past you did a great job and well appreciated. Hopping to see your next great app
Again Thanks.
First of all - BIG Thank You for this app/integration. Sad story but it is what it is. (And this is why I don't like anything cloud-based. Thanks GOD, now all my integrations are 100% local. Replica was replaced by Local Things.)
Question: How do i delete this app? I was able to delete all drivers and apps except for the Replica inself. There is no a DELETE button and as a result I cannot delete this integration and the related app code:
UPDATE
OK, I found a way how to remove the app. I am all set. And Thank you again.
Click the info top right. The ‘I’ in a circle.
Just one more reason for people to ditch smartthings altogether. I mean is there anything at this point that smartthings can run that hubitat can't? Or partity with applications both native and community based? I never had to use Hubithings but still glad for your all the time you put into it.
There are still some custom cloud integrations that SmartThings can handle. The only thing keeping me around this long was the Samsung TV and appliance integrations. I tossed my old ST hubs years ago.
Now that Home Assistant has LocalThings which talks directly to those devices without the cloud, that ship has sailed. And with the fairly robust integrations between HA and Hubitat, there really wasn't much reason left to stick around.
Let's be honest, SmartThings is the gateway drug of home automation. Once you get a taste of automation, you start craving more control. Eventually you realize that keeping things local is the only way to have a reliable smart home.
SmartThings gets you hooked. Hubitat and HA feed the addiction. ![]()
And I certainly will not miss the nonsense their marketing team keeps pushing onto the development side.
RIP - Thanks for all of your efforts. I have just uninstalled. I won't pay SmartThings any more than I have already paid. I still have 6 of their cameras and switches. (connected to cameras to reboot when necessary)
Everything else was migrated to Hubitat years ago.
...and everyone else, it appears they deprecated the delete part of the 'app' API too (not surprised). So you need to go into the funky developer console and delete out the OAuth. What a well thought out plan...that feedback button hopefully doesn't work. ![]()
Delete this:
Thank you for the tip. Done.
Top secret, I've just created a bridge to bring my SmartThings' Fibaro dimmers, relays, and plugs into Hubitat, locally, so I can use them for WebCoRE. Can I call it HubiThings V2 Bloodtick or have you trademarked the name?
I created a Python bridge (running in Heroku) that leverages PyAarlo and EMQX to bring some Arlo camera data into HE. SmartThings will not get another dime from me.
