New version on GitHub...
Bug fixes
Bug fixes
@bptworld, I'm fairly new to Hubitat and have been checking out Device Sequencer, which works nicely for sequential power-up, and I want to use it via a virtual switch that can be invoked from Google Home. What would be the best way to effect the following:
The use case is for controlling a stereo system, where the On sequence should be source-preamp-amp, while the Off sequence should be amp-preamp-source. Will this require RE to deal with the on/off conditionals? Or is there another way to finesse it? Thanks!
Welcome to Hubitat!
So you need it run in reverse order?
New version:
2.0.4 - 11/14/20 - Added Reverse order on off option
Damn Bryan - youβre a coding machine! It took less than 25 minutes from @john21βs request to your putting a new version on GitHub!!
lol, timing is everything. Besides, it was a very easy change.
Wow, it works!
One thing I notice.
For my use case, I'd like to build in a little buffer between power-off events. Can your code be tweaked to use the inter-device startup timing variables during the shutdown sequence?
Cheers!
Yup, looks like I missed this part. Give it another try.
New version:
2.0.5 - 11/14/20 - Adjustment
Perfectamundo, bro!
Thanks very much!!
