So question-- how difficult would it be to make the delay specific to the profile. For example, a 5 second delay when switching to profile 2, but no delay when switching to profile 1?
My use case is that I have lights turning on/off tied to mode changes. When I leave, all lights turn off and I switch BI to a profile that sends alerts on motion. But sometimes the lights going off triggers an alert. If I can delay the BI profile by several seconds this would avoid it.
But I also have lights turn on when I get home. So I'd like no BI profile delay when I switch to the no-alert profile.
I can also take a stab at making these changes and do a pull request.
I am new to trying out this app and also new to BI. I have a question on the authentication. In the app instructions, it states "Ensure 'Use secure session keys and login page' is not checked. Disable authentication, select βNon-LAN onlyβ (preferred) or βNoβ to disable authentication altogether."
But I see the app also asks for our connection credentials. So my question is, do we really need to disable secure session and authentication? I would really rather not disable authentication, even within my LAN.
BTW... Here is a screen capture of these options for the latest BI v5.
I turned off 'Use secure session keys and login page', since that still allowed me to use/enforce basic auth on BI. I can confirm this app worked to set profiles.
I now have a question...I noticed the absence of Profile 0 (Inactive) being available. Was that left out for any specific reason?
@bptworld - If you don't mind, I may also look at adding the lock options ("...set the lock=y, 0=run, 1=temp, 2=hold") for profile settings.
Just want to share a tip for those setting up manual recording. I could not get the recording to last longer then 30 seconds. After a face palm moment I figured out that in the global Blue Iris settings > Cameras >" Limit manual recording time to 30 secs" was set.
After changing this value I could then record for a defined time. In my case my interior cameras that DONT continuously record will now record for X minutes when BI Control triggers them.
This ability was something I moved off a large Arlo system for when they dropped the Smartthings integration.
Thank you so much for your work on this @bptworld. I truly appreciate your dedication to Hubitat apps.
Hey sorry im new coming over from the smartthings scene, i see its mentioned that this app has "Google Home" control. Does that mean i can set it up so i can say "Ok Google show me the ... Camera"?
Just setting up BI Control for the first time. Awesome concept, Bryan. Thank you!
My use case is to trigger a snapshot for a given camera when certain conditions in HE are met. I added the parent and then one child app, and keep getting the below error in the HE log. I've triple checked BlueIris IP address and port, as well as camera shortname. No image shows up in my folders. Any ideas?
app:23472020-02-15 08:11:07.655 pm errorError: groovyx.net.http.ResponseParseException: Not Found
app:23472020-02-15 08:11:07.377 pm infoParent Installed OK
app:23472020-02-15 08:10:38.599 pm errorError: groovyx.net.http.ResponseParseException: Not Found
app:23472020-02-15 08:10:38.297 pm infoParent Installed OK
app:23472020-02-15 08:10:20.835 pm infoThere are 0 child apps
app:23472020-02-15 08:10:20.815 pm debugUpdated with settings: [biPort:81, biPass:PASSWORD_REDACTED, biServer:10.0.0.6, biUser:Admin]
app:23472020-02-15 08:10:02.542 pm errorError: groovyx.net.http.ResponseParseException: Not Found
app:23472020-02-15 08:10:01.926 pm infoParent Installed OK
app:23472020-02-15 08:09:42.202 pm infoThere are 0 child apps
app:23472020-02-15 08:09:42.193 pm debugInstalled with settings: [:]
Yeah sorry I should've said that. I unchecked "Use secure session keys and login page". And authentication is set to "Non-LAN Only". And, FWIW, the login credentials I'm using is for a user with admin privileges. Hope that helps.
The only thing that jumps out is that you said that you created a child app. According to the logs, 'There are 0 child apps'. I would suggest deleting the child and parent app and starting over.
Other than that I would suggest to double check the password.
I've honestly never seen that error before so I'm kinda at a loss as to what it means.
Hmm I tried that. I deleted the child and reinstalled. No joy. Then I deleted both the parent & child and reinstalled both. Same error. I think I just copied the log at the wrong moment. That error message keeps occurring.
@bptworld, just spoke to BI support. They asked if we could show them the web request that your app fires to request the snapshot so they could troubleshoot the problem. Can you point me to a line in the code, or?
EDIT: Actually, belay that. I have a theory. And I'll preface this by saying that I'm absolutely not a Groovy developer, but I am a hopeless tinkerer.
On line 497 of the BI child app, the code is:
biRawCommand = "/admin?camera=${biCamera}/snapshot&user=${parent.biUser}&pw=${parent.biPass}"
Is it possible it should be this (the slash before "snapshot" changed to an ampersand):
biRawCommand = "/admin?camera=${biCamera}&snapshot&user=${parent.biUser}&pw=${parent.biPass}"
I tried it and it worked. Wonder if it's just a simple typo?
