Seems like this should be easy, and I'm sure I'm just missing or misunderstanding the required option.
I have lighting rules that work fine for turning on and off after a delay, but I'd like to incorporate a backup for when the wife "accidentally" turns off the lights manually.
The "Don't turn on if turned off manually" option would be ideal if I could set a delay / timer around it rather than waiting for the next mode change.
I'd like to delay the ML from turning the light back on for X minutes after being turned off manually. So if you leave the room and turn off the switch manually, but come back in 5 minutes or less, don't turn on the light. But after 5 minutes, DO turn on the light on motion.
Sort of the opposite of "cancel delay". What am I missing?
