This must be covered someplace but I've not found it...
The battery went dead in one of my Aeotec TriSensors.
What is the proper procedure for replacing the battery?
Winter is coming so I picked up a lithium battery and replaced the original.
I, naively, thought I would just replace the battery and away it would go.
I tried letting it sit for awhile. It never connected. I tried doing the replace operation on the z-wave device page. It didn't do seem to do anything. I also tried just doing a rediscover without removing it to no avail. There were some scattered z-wave repairs in there as well.
I tinkered for quite some time after installing the new battery and I ended up having to remove the apps using it, forcefully remove the device, factory reset it, hard boot the hub, rediscover the device and recreate the apps. It only had two associated apps so not that big a deal but there has to be a better way to do this. The next time one goes dead I'd prefer not taking this path.
Any pointers appreciated!
