As you can see, I have been able to manage all my dashboards in apple watch thanks to the shortcut application. Everything is working well, but I was wondering if I can get rid of the red area in the picture ( It is basically the row where the green check and dashboard setup icon are). This will give a much cleaner dashboard and more space for the switches to display. Thanks in advance.
If CSS is the way to go, can you please show me the commands associated to this particular area of the dashboard?
In hubitat
1.) You go in your hubitat menu to applications
2.) dashboards and click on the one you want
3.) you go to the bottom and right click on the option "cloud link to dashboard"
In your iphone
1.)You have to use shorcuts app in Iphone
2.)you create a new shortcut
3.) you add an action to the shortcut
4.) you click on open URL and paste the link you created before
In your watch
You open shortcut app and your created URL shortcut should be there and now you can control from your watch....
One more ? for you experts. I was planning to only use the watch dashboard when I was at home. Can I copy the link for the local dashboard and use it instead of the cloud? Can I make 2 shortcuts, 1 for local and one for cloud?
For those of you who are using the Apple Watch and shortcuts , just to let you know that after IOS 15 you need to use in shortcuts the command show webpage at URL instead of Open URL
