Dashboard won’t control water valve
I have a dashboard setup for all things water. For some time now the water valve will not respond from the dashboard. All automations work, everything works fine from the device page, and even my HomeKit dashboard works. But not my Hubitat dashboard. It just gives me the clock every time I try to operate it.
Any ideas?
I’ve had similar issues with the valve device type on the dashboard wanting to get acknowledgement of closed before returning control. However, for my valve, if it wasn’t closed, the thing I wanted to do was to close it again. But I couldn’t from the dashboard at that point.
I ended up making Water a virtual switch which would, in a rule, repeatedly turn the valve off, power cycle the valve, etc. until is reported closed. This worked well for me since I also wanted to turn off a hot water recirculator and the well pump as part of turning off “water.”
That clock icon usually means the dashboard tile is still waiting for the valve to report the state it expects, so I would first remove the tile and re-add it, checking that the device is still authorised for that dashboard and trying the Switch template as a test. If the Switch tile works while the Valve tile hangs, the issue is likely the valve attribute the template is watching rather than the device itself. It is also worth checking the hub logs while you tap the tile, since an error there will tell you whether the command is failing or simply never getting its expected acknowledgement.
If you look at Current States in the settings pages, do Current States reflect the reality of the physical device? In other words does valve physical open say Open on Current States, and same for closed?
Can you screenshot your Current States, and paste it here? Also, what device brand/model is this, and what driver (device Type) is it using?
