Dashboard tile transparency
I added a background image to my dashboard. Some tiles are solid and some are semi-transparent. It appears that all the tiles that use a template I have customized are solid, while the default templates are semi-transparent. I do not see transparency anywhere in the template options. Any way to make the customized ones have the same transparency as the default ones?
Tagging @TechMedX for the win!
This slider is transparency:
Unfortunately, it doesn't show the transparency value to match the exact number of the default transparency but you should be able to get close.
EDIT: If you want to get real sneaky with a motion or contact sensor and only want it to show when active/open, make the inactive/closed color & background colors 100% transparent.
The easiest way to change all tile of a type is as @stephen_nutt posted.
If you needed to be exact (or have different colors/levels for similar device types) it would need to be done via JSON/CSS. Here's a sample
  "template": "switches",
  "bgColor": "rgba(33,100,223,0.9)",
  "iconColor": "rgb(2,2,2)",
  "state": "on"
At the end of the color line, the 0.9 is the opacity (opposite of transparency, 0.0 is transparent 1.0 is solid color).
D'oh! It's right there and I missed it. Thanks!
That's my style!!!!!! but I appreciate learning how you can do it more precisely.
