I was experimenting with changing the background color on the Switch template for the Off state in one of my dashboards today, and I cannot change it back. I am on version 2.1.4.130, using the latest Chrome on Windows 10.
When I click "Remove" under the Background Color box and click "Save", then close that dialog and refresh the page, I see the change did not take effect. When I go back into the Template Color Editor, I see the previous color still remains. Also a weird behavior, when I click back and forth between the States for Switch, the Background Color box does not change. It remains showing the color selected for Off.
I also tried to just remove the "customColors" block from the Layout JSON. When I click "Save Layout JSON", I get error "Cannot read property 'filter' of undefined".
I am starting to think I am going to have to recreate this Dashboard to get back to the original state.
Maybe not a solution, since I don't have this bug. But something to try... Did you try to remove the customColors section from the JSON? Same result as the op? If so, copy the JSON, remove customColors and paste in a new empty dash. If this doesn't work, paste the JSON here and I'll have a look.
I did as you recommended - was able to delete those "customColors" settings from the Layout JSON under "Advanced" in the dashboard settings and it did the trick! The button templates that were problematic are back to the way they were before.
I really hope they spend some time on improving the dashboard again soon... It is quite useful, and there is so much that could be added/improved to make it easier to use!
Been helping with a Dashboard-related project lately, have dug myself into how it works and even read through must of the JS-code by now.
This should work, the times it doesn't would be when there is corruption in the DB or connection issues to the hub. Or if the editing of the JSON was done wrong... Neither of these things are use-friendly...
So do we all, there's a neat release related to this coming from another dev soon, you might like it
