Dashboard stuck on Sending with Shelly 1
Hi everyone,
I get a similar issue that was reported before here and there in the forum...the dashboard icon stays stuck on "sending" with the hour glass when I try to turn on or off the shelly switches. The switches respond normally though, they turn on and off. The problem is really with the dashboard display of the device state.
Note on the device type:
Shelly 1 switches use a parent and a child device. The parent device type is "Shelly WIFI switch" from the community. The child device type is "Generic component switch" and cannot be changed (greyed-out).
Anyone has had a similar issue and or a fix ?
To rename the child device put the name in device label underneath the "Generic component switch" field. You might have the parent linked on the dashboard instead of the child.
