Dashboard Pin Requirement
Just today I find that to access a dashboard I need to enter the PIN. I have gone to the Advanced of the dashboard(s) and removed the "Allow Access to this Dashboard via Remote / Cloud Links", That selection is saved correctly when I select 'Done'. I have also removed the 'pin' but when selecting 'Done' it returns.
I don't want or need that type of security on Dashboards that are used only on my local LAN but I see no way to remove this requirement.
I have another hub that does NOT show the pin value in the Advanced section.
How can I fix the problem hub/dashboard?
Regards,
Milt
The issue is with both the PC and the iOS devices. This just started happening and I have no idea how to resolve the issue.
I do NOT want any security when accessing dashboards locally. This is a new problem.
I have a second hub, running the same version (2.3.9.158) and it does not show the same problem.
The problem is with Firefox. If I attempt to remove the pin and select 'done' it returns. If I use chrome, the pin remains cleared.
Chrome, however, has and always has had major problems with the control of font size and it does not show glyphs at all.
