It would be great if there was a option to have multiple pin codes for dashboards.
Like if using Lock Code Manager, allow following users to use their pin on current dashboard.
So rather than "Require a numerical pin to be entered before sending an HSM command." if Lock Code Manager is used provide a drop down of user to select.
And then give the ability to record the info of what pin was used, so we can create a rule based on the user code entered.
Goal:
To use a tablet / Dashboard. and allow users to arm and disarm system and based on user I can run a particular rule and send notification who armed or dissarmed system.
When selecting Dashboard icon - HSM, ability to remove/hide/rename options.
Example: I would like to only show Arm Home, Arm Away, Disarm All and hide Events, Alerts
Even better would be to give the option of a virtual keypad when pressing HSM, so it would look like a keypad on the wall. Top would show current State, and then the options for arming disarming (According to selection) and then a number pad. so we use it like a real keypad.
This will make it easy for guests staying over and such.
And if we could control the pin requirements by icon/device instead of whole page.
Also it would be nice that once a pin was entered and press go, that the HSM would also close automatically..
