I noticed that even tho I have a dashboard set to not allow editing, when the dashboard is loading the gear icon shows up. If I'm quick enuf it allows me into the edit mode. Not sure if this is intended, but can see where it might be an issue.
You are right this is an issue. When I've tried the gear I turn off the hide 3dots option or make another change and hit ok but the change never takes place even after a refresh, it does seem to stay how you set it when you go back into the gear but still doesn't seem to affect the dashboard.
However in testing now, I noticed that if I click the + during the refresh I can add tiles like my locks or garage door then they do show up and I'm able to unlock or open the door when I shouldn't have even been able to add it. This is on a dashboard I only had a passcode to enter not one to execute commands since I didn't have any tiles that could be executed until I was able to add some through this issue.
