Dashboard links generated incorrectly
I'm managing my hub through its static dhcp address. working fine. but when i load Dashboard, all of the dashboards link to http://169.254.9.63
in the source, i do see:
var localIp = "169.254.9.63"
I think this is because the hub booted before my dhcp server and/or switch was online. it probably generated the dashboard page while the ip address was in the 169.254.0.0/16 link-local.
is there a solution besides rebooting the hub? any secret 'regenerate' button?
if that's the problem, maybe something can detect that it's in 169.254 and fork off a task to retry later. or use hooks (if the hub uses dhclient)
I've had the exact same scenario happen to my hub on many occasions. I have sent an email to support outlining the issue and have been told it's been referred to the engineering team, but no update since.
As you've found, the only way I have found to fix it is to perform a reboot of the hub.
