Dashboard linking after v2.2.4
Since upgrading to v2.2.4, my Dashboard links are not working. When I click on one, I get the pop up error of "Dashboard Link Tile only work with Legacy Dashboard links". I edit the tile and confirmed it is pointing to the other Dashboard. Anyone have an idea how to fix this?
I've been using the Link tile instead of the Dashboard Link tile; does require that you manually provide the URL though.
I know this horse was beat dead long ago - but I still do not understand one thing about the new Link tile. With legacy Dashboard Links the tile worked in both the local and cloud dashboards - is that possible with the Link tile?
The problem with using this link is the logo will take you back to all the dashboards.
I have the same problem as k5map. What is called the dashboard link won't work.
Yes what gives
I've started to have this problem again too, not sure what the issue is. I was on 2.2.7, upgraded to 2.2.8.156 this morning, but still get the error message when trying to navigate with dashboard link buttons
