Hi
I have a 'main' dashboard, there i have a quick overview on the 1st floor.
If i want/need i can acces the history of the device with the famous '3 dots'
but having a younger son and a clumsy girlfriend i want to disable some of those 3 dots but not all.
for example I wanna look at the history of a motion sensor if there was a thief. But i don't need to be able to se the history of a aqara temp/humid/pressure sensor
unless captain cold is comming
second example On my dashboard i have my tiles but since my girlfriend isn't that good in reading a selfmade blueprint I grouped them using a bigger tile with a text. but there is no need to use those 3dots
thx for the input.
I use chrome and followed the step by step guide you arefully made for me.
It didn't work. I did 'inspect' but I did not see a 3dot symbol of any kind.
time for plan B:
I took your code,
#tile-5
.tile-edit {
display: none;
and just paste it into the CSS tab.
For the tile id number it was just a matter of hitting the 3 dots and read in the left corner
" |< Edit Tile ID: XX >| "
but again no luck.
It apears that the whole tile just disapear and not only the 3 dots but also the value (text in my test)
guys... think i found it. @TechMedX and @furom
I kinda combined both ideas...
used the one persons code and tried the others method of ditching those 3 dots.
