This is great and wish was part of the default. I used your ccs code and made a few tweaks but I am not able to remove the % at the bottom of the tile.
Not sure what I am missing.
Thank you for your work.
Same. Maybe @spelcheck could add it as an option for Smartly tiles.
Are you trying to remove the number + %?
Yes, since the number is in the slider it is just duplicate and taking up space.
I would like to remove all that is in the red circle and then be able enlarge icon or move slider down.
Thank you
.tile > .tile-contents > .tile-primary div:nth-child(3) { display:none !important;}.
This should do it for ya.
Is it possible to change the slider from 0 - 100 to 0 - 30? I'm trying to use the slider to set the manual watering time for the Rachio Zones, and would like to limit it to 30 mins to prevent overwater. Thanks.
Edit: I'm using a Volume template.
I’m not sure if you could do that with CSS. Maybe there’s some way to override it in the material part of the code...
An alternative would be a to make a rule that converts 0-100 to 0-30.
(Percent/100)*30 is the math to do that. If the level slider changes, convert the number, and set your valve to turn on for that many minutes. It’s a bit clunky, but it would work.
Edit: Material might have some form of a limit. It’s worth checking out.
I think the path I will take is the one you suggest. Do the math to limit the highest value, and then will take out the slider number% indication.
You could also put a small tile adjacent to this one showing the number selected
This is great!
Does anyone have an idea of what CSS I would use if I want to change the color of the slider rail, border, and percentage when a dimmer is on?
Just found this when looking for a fix for the dimmer slider button not following the icon/text color and just staying bright white. This fix cures that and adds the percentage. Great!
Thanks @adamkempenich
