Is it possible to remove the null for Illuminance for the Hue motion sensors connected directly to Hubitat. Happens for all levels.
Is this the built in driver?
Yes.
Thanks, will put in a ticket to update the built in driver to provide unit of lux. Devices should report their unit of measurement. You can use the attribute tile if you want the raw value without the unit.
yeah, i already tried that, but it didnt work.
what didn't work? Using the attribute tile? This should work as long as the attribute name matches what's in the state of the device.
Tried again, working. Must have been user error. Thanks.
