Dashboard adding new devices
Hello I've tried to search this topic and couldn't find any result. I have a dashboard created and since the creation I've added 2 zwave doorlocks to hubitat. I've gone to apps and updated the dashboard. When I then go to dashboard I don't see the 2 doorlocks. Does the dashboard need to be refreshed? If yes...how do I do that?
thankyou in advance
You have to add the tile to the dashboard. Adding it in apps only makes it available to be added, but doesn't change the dashboard itself. You can have all of your devices available to the dashboard if you want โ€” but I wouldn't recommend it as it can tend to slow that dashboard down a lot.
To add the tile, click on the little + up in the corner, on the popup select your device and its type and hit "add tile".
And if youโ€™ve done that but your device isnโ€™t showing up in the add tile list, the green check mark :white_check_mark: is the refresh button.
Thankyou! I didnt do the Add Tile part.
Much thanks....
That worked!!!!
Glad I could help! Have fun with your dashboards!
