Daikin VRV control
Is there a way for HE to pass commands from a wall thermostat into a Daikin VRV Fan Coil in order to control heat/cool and fan speeds? Presumably would need some kind of hardware between (think it talks on modbus) but I can't find any documentation on this.
There is a Daikin One Plus thermostat integration in the package manager. If that's what you use, then it should work
Hi. Thanks for this, but I think that this is for North America only, not UK, plus control I'm trying to achieve is over older VRV system. Not sure if Daikin One works with this.
