Custom Zigbee state after power loss
I'm trying to add this function to a wall outlet that lets you select which way I want it to come back after a power outage (this can be done in the Tuya App and in Home Assistant, it´s a Zigbee outlet), but I haven't found anything about this in the Hubitat documentation that allow me to add this funcion in a driver
Did you write this driver? You can't customize "stock" (built-in drivers), but you can do whatever you want in a driver you wrote on your own--as long as you know how to communicate with the device to achieve your result (which is the role of a driver on Hubitat).
