Custom/Synthetic Capabilities?
I have a FGRGBWM-441 that I have wired up to a 12V (dumb) motion sensor and a dimmer potentiometer.
I have it all "working" with the motion sensor triggering lights via the 10v inputs and such but for now I'm just using a ported version of this handler for verifying my breadboard wiring.
The next step is a custom device handler, ideally I "hide" the real capabilities of the FGRGBWM-441 and have the handler expose a device that actually has:
capability "Configuration"
capability "Energy Meter"
capability "Motion Sensor"
capability "Polling"
capability "Power Meter"
capability "Refresh"
capability "Switch Level"
capability "Switch"
To make it look like a motion sensor dimmer switch with energy usage monitoring.
Is it as simple as just declaring the capabilities I want and making sure the logic in the handler does the right thing?
Thanks for helping a noob device handler author.
Yes, pretty much. Each capability has commands that must be implemented. You can find the commands each capability has here.
https://docs.hubitat.com/index.php?title=Driver_Capability_List
Implement a method for each command (plus any helper methods you need) and you're essentially done.
Awesome, thanks!
So the capabilities declared in the handler are orthogonal to the actual ZWave events the handler uses to communicate with the device?
I would say they can be directly related or not. Some of the capabilities have a z-wave message that nearly directly associates to the capability. Others, there is a z-wave message for multiple capabilities.
There are lots of GitHub.com drivers for Hubitat devices. Take a look at one of them. There is typically a parse method for every type of Z-Wave message the device supports. The response from each command is parsed in those methods and the device's states are updated.
Capabilities define a device driver interface specification.
It is an abstraction layer that exists between the physical device command layer (zigbee, zwave, lan, whatever...) and Hubitats event and command schema.
The role of a driver is to translate the required capability commands and attributes back and forth using the devices native protocols.
A given capabilities commands are converted to device specific commands and sent to the device.
The device responses are converted into capability attributes and sent to the event system.
All very interesting! My first Hubitat hub is on order, when I get it I'll be aiming to port all my device handlers over... though it seems like others have already beaten me to it! :slight_smile:
