Current State. What makes it show?
Which is just a DHT22 with different packaging, I believe... :wink:
Another option you might be interest in, if you want something smaller and Zigbee, is @iharyadi's Environment Sensor. It does temperature, humidity, barometric pressure, illuminance, and is a Zigbee repeater. If also has some GPIO pins that you can use as you see fit. Very cool device!
