Current Recommend Garage Door Opener/Closer
yes mine is working though I would not buy one again. Had 2 but the tilt sensor fell off the door and I drove over it and you can not replace the tilt sensor so it is useless. replaced it with a mimolite and magnetic door sensor the other one is still working though. I am not home but I believe I modified Rboy's garage door DH.
For the mimotelite and magnetic door sensor I modified the following code (not my code) to work with Hubitat.
 *  MIMOlite device type for garage door button, including power failure indicator.  Be sure mimolite has jumper removed before
 *  including the device to your hub, and tap Config to ensure power alarm is subscribed.
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Updates:
 *  02-18-2016 : Initial commit
 *  03-05-2016 : Changed date format to MM-dd-yyyy h:mm a
 *  03-11-2016 : Due to ST's v2.1.0 app totally hosing up SECONDARY_CONTROL, implemented a workaround to display that info in a separate tile.
 *  08-27-2016 : Modified the device handler for my liking, primarly for looks and feel.
 *  01-08/2017 : Added code for Health Check capabilities/functions.
 *  02-11-2017 : Cleaned up code, and used secondary_control again for messages.
 *  03-11-2017 : Cleaned up code.
 *  03-24-2017 : Changed color schema to match ST's new format.
 *  04-08-2017 : Updated the updated() section to call configuration().
 *  05-19-2017 : Added additional attributeStates to match ST's DTH which should make this work with ActionTiles, and to use contact as the main tile instead of switch due to personal preference.
 *  05-20-2017 : Redefined tiles/names to be similar to the Linear-type opener DTH's, which should make this work with ActionTiles.
 *  05-23-2017 : Made the delay longer for retreiving device info (gets) after the main tile or the refresh tile is tapped.
 *  09-22-2019 : converted DH to Hubitat and added refresh before each action
 *  10-07-2019 : removed extra refresh from open/close it caused to much delay
metadata {
	// Automatically generated. Make future change here.
	definition (name: "MIMOlite Garage Door Controller 10/07/2019", namespace: "Hubitat", author: "scgs350") {
        capability "Momentary"
        capability "Relay Switch"
	    capability "Polling"
        capability "Refresh"
        capability "Switch"
        capability "Sensor"
        capability "Contact Sensor"
        capability "Configuration"
	    capability "Actuator"
	    capability "Door Control"
	    capability "Garage Door Control"
        capability "Health Check"
	    attribute "powered", "string"
        attribute "contactState", "string"
		command "on"
		command "off"
        command "open"
        command "close"
def updated(){
	// Device-Watch simply pings if no device events received for 32min(checkInterval)
	sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
    response(configure())
	// log.debug "description is: ${description}"
	def result = null
    def cmd = zwave.parse(description, [0x72: 1, 0x86: 1, 0x71: 1, 0x30: 1, 0x31: 3, 0x35: 1, 0x70: 1, 0x85: 1, 0x25: 1, 0x03: 1, 0x20: 1, 0x84: 1])
    //log.debug "command value is: $cmd.CMD"
    if (cmd.CMD == "7105") {				//Mimo sent a power loss report
    	log.debug "Device lost power"
    	sendEvent(name: "powered", value: "powerOff", descriptionText: "$device.displayName lost power")
    } else {
    	sendEvent(name: "powered", value: "powerOn", descriptionText: "$device.displayName regained power")
	if (cmd) {
		result = createEvent(zwaveEvent(cmd))
	// log.debug "Parse returned ${result?.descriptionText}"
    def statusTextmsg = ""
    def timeString = new Date().format("MM-dd-yy h:mm a", location.timeZone)
    statusTextmsg = "Last updated: "+timeString
    sendEvent("name":"statusText", "value":statusTextmsg)
	return result
def sensorValueEvent(Short value) {
	if (value) {
        sendEvent(name: "contact", value: "open")
        sendEvent(name: "door", value: "open")
        sendEvent(name: "switch", value: "on")
        sendEvent(name: "contactState", value: "Door is open, close/off to close")
	} else {
        sendEvent(name: "contact", value: "closed")
        sendEvent(name: "door", value: "closed")
        sendEvent(name: "switch", value: "off")
        sendEvent(name: "contactState", value: "Door is closed, open/on to open")
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
	def doorState = device.currentValue('switch')
    if (doorState == "off")
    	[name: "contactState", value: cmd.value ? "close" : "closing", type: "digital"]
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
	sensorValueEvent(cmd.value)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
	sensorValueEvent(cmd.sensorValue)
def zwaveEvent(hubitat.zwave.commands.alarmv1.AlarmReport cmd)
    log.debug "We lost power" //we caught this up in the parse method. This method not used.
def zwaveEvent(hubitat.zwave.Command cmd) {
	// Handles all Z-Wave commands we aren't interested in
def on() {
    log.debug "Sending on event to open door"
	open()
def off() {
    log.debug "Sending off event to close door"
	close()
def open() {
	if (device.currentValue("door") != "closed") {
		log.debug "not opening door is already open"
	else {
        log.debug "Sending open event to open door"
		push()
def close() {
	if (device.currentValue("door") != "open") {
        log.debug "Not closing door since it is already closed"
	else {
		log.debug "Sending close event to close door"
		push()
def push() {
	log.debug "Executing push for garage door"
	delayBetween([
        zwave.basicV1.basicGet().format(),
        zwave.basicV1.basicSet(value: 0xFF).format(),
	],1000)
def poll() {
	refresh()
// PING is used by Device-Watch in attempt to reach the Device
def ping() {
	refresh()
def refresh() {
	log.debug "Refreshing"
	delayBetween([
		zwave.switchBinaryV1.switchBinaryGet().format(),
		zwave.sensorBinaryV1.sensorBinaryGet().format(),
//		zwave.alarmV1.alarmGet(alarmType: 0x08).format()
	],1000)
def configure() {
	log.debug "Configuring...." //setting up to monitor power alarm and actuator duration
	delayBetween([
		zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
        zwave.configurationV1.configurationSet(parameterNumber: 11, configurationValue: [25], size: 1).format(),
        zwave.configurationV1.configurationGet(parameterNumber: 11).format()
	],100)
