I have a simple tile driver that displays text on a dashboard tile. It also changes color. For some reason the background is not the full width of the tile. Below is the code I am using. If I change the width to more than 100% it does make it fill out but then the text is offset. I'm sure this is simple, but I can't quite figure out what to change. Any ideas?
That one displays the content from the tile-secondary div IIRC. Itβs about 2 layers down into the tile, and so will need a little manipulation - lot of good examples in this thread:
