It appears that the link to the Cron Expression Generator at https://www.freeformatter.com/cron-expression-generator-quartz.html# leads to a site that is currently down.
AI is quick and easy to generate Quartz Cron Expressions from plain English.
There is a note on the site now:
Thank you for the bug report.
Tagging @bertabcd1234 @gopher.ny
FWIW, if the cron expression generator link in Rule Machine is to be changed, then crontab.guru is registered till 10/2027.
Next build will have a local cron expression builder, with links reflecting the change.
