You would have the same issue with the built-in driver regardless of data type in this case (though I agree it should be specified). No change means no event. If you want your rule to do something even without an event, you'll need to add something to make that happen. Maybe a time-of-day check or something in another rule?
Yes you are correct. Just updated rule to trigger on sunup and sunset. Thank you!
