want to see if I can create a double tap within a driver, so within the event case I found some code which does similar. Would this work, or is there a better way to do it.
It's just a case statement with a trigger from a device above this and a break below. So if the event of a press happens this runs.
I can't seem to get it working, essentially in sudo I think I want the below or though I'm not sure if it's the best way to do it or if it would even work. That's why I found that example above.
Button pressed
Add to NumberPressed
Wait 0.5 seconds
If 1 then
send pushed
Else
Send double tap
End if
Set NumberPressed to 0
The thing that will get you is the wait for .5 seconds. You'll need to have the event register the button press and do the variable count, but schedule a method to run after the delay period to check the count, send the appropriate event, then reset the variable to 0.
There is a void parse (string X) {
then it maps that parse X
Then tests that in a IF (test) {
switch (eventFromMap) {
Case "1":
Then the push event which I want to work out if it can be a double tap,
so pasted you code and sorted the send events.
break
other cases etc
} end of case
} end of void
