Could not find which method setLevel()
happens when trying to set level on a bulb from a dashboard tile:
2018-05-08 19:55:33.170:errorCould not find which method setLevel() to invoke from this list: public java.lang.Object GenericZigbeeRGBWBulb#setLevel(java.lang.Object) public java.lang.Object GenericZigbeeRGBWBulb#setLevel(java.lang.Object, java.lang.Object) on line null
@mike.maxwell do you need anymore information on this one?
thanks.
Nope, that'll do thanks!
What firmware are you on?
1.0.8.711
What level are you trying to set?
Also, if you open f12 console, what does it show for sending cmd?
light level ... not sure if thats what you are asking?
range of 0 to 100 which value are you trying to send on the slider?
cant reproduce anymore ... had gone away from the dashboard ... now back in but doesnt error anymore
think it was around 30s
ok, if you see it again, try to capture the f12 console cmd that was sent. It can't really send anything other than 0-100 but somehow the hub is getting an object instead.
Also, what browser, os, etc.?
Chrome Version 64.0.3282.186 (Official Build) (64-bit)
System Version: macOS 10.13.4 (17E160e)
