How are you planning to use this data, specifically? I'm asking because it's device metadata only and does not generate events, so it could not be used as a trigger, but there are would likely be ways to do what you want.
Using Maker API to do something on the same hub as Maker API itself is almost always the weirdest possible way you can do whatever it is you're doing, though it might work -- but in any case, we really need the answer to the above about how the data is to be used, as this doesn't do anything differently than mentioned there (e.g., it still could not trigger a rule).
Devices disappear and I want to alarm when they do . There is a github added function, but I would like to just access what seems to be a simple variable from within rule machines.
I have a periodic procedure that checks batteries, and gives me a voice prompt when they go dead. But often these devices go away before they can report their batteries are low.
I want to get rule machine to sense a missing device and issue a http get.
My question was more about how: with a periodic check? That's probably the best you can do, as the value of this data changing does not generate an event on the hub, so it cannot be used to "trigger" an automation directly in that sense. But it would be good to know that before pursing any particular option.
Yes, I would be fine with a periodic check. In fact, my battery check currently works that way. It checks the batteries of all my devices at a particular time of day and gives an audible alarm.
If you join the "owners" group, you'll be able to post links (and images): Hub owners - Hubitat
But I know what you are referring to, as I wrote that app.
If you have any interest in (sort of) writing custom apps, it may be easiest to simply modify it to send an HTTP call do your device directly instead of sending the notification. Alternatively, an option like the ability to "push" a virtual button device or similar would make a usable trigger in Rule Machine. Neither of these features exist in the app right now, and you could also write a simple one to meet your specific needs, but since RM cannot access these values directly, I'd say that's probably the best option. Or at least that's what I'd do!
Very cool. I didnt know you wrote it. I will look into coding it as I do some coding from time to time. Maybe I will generalize it to be an app that publishes "inaccessible data" to hub variables so anyone can get to anything.
The other thought I had was using a virtual notifier. I looked and I did not see what looked like a generic virtual notifier. That seems like a great app to have. Where the virtual notifier could be a connector to http or other functions.
You could probably get by with just the driver for you use case and modify it to send an HTTP call when deviceNotification() is called, then use that device in my app (or whatever) instead of a "real" notification device.
(The intent with my app and driver together was to use one "proxy" notification device like this to send that notification to one or more "real" devices, useful without needing to select them all in every app individually or switch out the devices easily if you change for whatever reason -- but it's pretty simple and could be easily modified or the driver used alone.)
