Am I missing something basic?
I want the LED of this to be on when the switch is off (dark bathroom).
There is an option, but when I select it then save preferences, nothing happens.
Switch is Zemismart and I'm using the custom driver.
Changing of the power-on behavior is a one-time command to the device in this driver, not an option (preference).
It works similar to the other Commands - you need to press the Command button. Some commands are simple, without any parameters (On, Off, Refresh..), other commands require a parameter to be selected first, then you must click on the button above the parameter ( 'Led Mode')
Select the option
Click on the button (the previously selected 'toggle' option should be visible)
You don't need to click on the Save Preferences button.
Fantastic thank you!!
