Hello, I just got my hubitat connected and connected my kwikset obsidian 954 lock to it and it works but I want to control it with an easy to use app like smarthings which i use at another location which has an aeotec hub. Will I be able to connect the 954 lock in this house with only a hubitat C7 hub to the smart things app so I can control this locl from the smarthings app instead of using the hubitat remote access app? I just like the smarthings app better because its so easy to use, I am not a tech savy person, the hubitat is really over my head. I just want to set a simple automation and use the smarthings app to control this lock in this house that only has the hubitat hub.
There is a way using HubConnect, but if you’re looking for something simple that’s not it. Your simplest solution would be to create a dashboard for the lock in HE. This document should walk you through it:
Creating Your Dashboard
And even that way might disappear when SmartThings abandons Groovy later this year.
