I've got an issue with my Yeelights currently. I am turning them on with the Yeelight app no issue, but with HE they are uncontrollable. In the logs I am getting these errors constantly:
dev:88 2019-08-03 02:06:35.120 pm error Telnet connect failed, trying again in 120 seconds...
dev:83 2019-08-03 02:06:35.124 pm error Telnet connect failed, trying again in 120 seconds...
dev:290 2019-08-03 02:06:38.106 pm error Telnet connect failed, trying again in 120 seconds...
Any ideas as this is a HE driver @mike.maxwell ?
Did you enable remote access for each bulb in the yeelight app?
all 12 bulbs have had LAN control on and been working in HE no issue.
all 12 bulbs can currently be controlled with the Yeelight app - no issue. Some of them (roughly half) can't be controlled by HE.
The pair in the living room - same bulbs, both been working flawlessly until my hub lockup today
hub lockups
living room A - heartbeat every 2 hrs no issue
dev:432019-08-03 02:16:38.118 pm debugheartbeat- message sent...
dev:432019-08-03 02:16:38.114 pm debugts- ct:1564805798112, lhb: 1564805678127, age: 119985
dev:432019-08-03 02:16:38.112 pm debuggetReTry- reTryCount:0
dev:432019-08-03 02:14:38.106 pm debugheartbeat- message sent...
dev:432019-08-03 02:14:38.105 pm debugts- ct:1564805678094, lhb: 1564805558118, age: 119976
dev:432019-08-03 02:14:38.098 pm debuggetReTry- reTryCount:0
living room B - is up to 304 retrys to connect.
dev:442019-08-03 02:18:41.126 pm errorTelnet connect failed, trying again in 120 seconds...
dev:442019-08-03 02:18:41.125 pm debuggetReTry- reTryCount:304
dev:442019-08-03 02:18:41.123 pm debuginitialize error: No route to host (Host unreachable)
dev:442019-08-03 02:18:38.122 pm debuggetReTry- reTryCount:303
dev:442019-08-03 02:18:38.120 pm debugts- ct:1564805918116, lhb: 1564787318102, age: 18600014
dev:442019-08-03 02:18:38.119 pm debuggetReTry- reTryCount:302
dev:442019-08-03 02:16:41.138 pm errorTelnet connect failed, trying again in 120 seconds...
dev:442019-08-03 02:16:41.135 pm debuggetReTry- reTryCount:302
dev:442019-08-03 02:16:41.133 pm debuginitialize error: No route to host (Host unreachable)
dev:442019-08-03 02:16:38.128 pm debuggetReTry- reTryCount:301
dev:442019-08-03 02:16:38.127 pm debugts- ct:1564805798125, lhb: 1564787318102, age: 18480023
dev:442019-08-03 02:16:38.125 pm debuggetReTry- reTryCount:300
Power cycled the bulb, no change.
Power cycled the wifi router, no change.
A different bulb though has come back by itself, any thoughts how to get them all back @mike.maxwell
dev:882019-08-03 06:50:32.067 pm debugts- ct:1564822232064, lhb: 1564822112091, age: 119973
dev:882019-08-03 06:50:32.064 pm debuggetReTry- reTryCount:0
dev:882019-08-03 06:48:32.075 pm debugheartbeat- message sent...
dev:882019-08-03 06:48:32.072 pm debugts- ct:1564822112071, lhb: 1564822091895, age: 20176
dev:882019-08-03 06:48:32.069 pm debuggetReTry- reTryCount:0
dev:882019-08-03 06:48:12.065 pm infoTelnet connection to Yeelight established
dev:882019-08-03 06:46:35.047 pm errorTelnet connect failed, trying again in 120 seconds...
dev:882019-08-03 06:46:35.045 pm debuggetReTry- reTryCount:589
dev:882019-08-03 06:46:35.043 pm debuginitialize error: No route to host (Host unreachable)
Haven't changed anything and a large group of them all just reconnected
dev:472019-08-03 06:48:12.087 pm infoTelnet connection to Yeelight established
dev:832019-08-03 06:48:12.038 pm infoTelnet connection to Yeelight established
dev:462019-08-03 06:48:11.996 pm infoTelnet connection to Yeelight established
dev:442019-08-03 06:48:11.963 pm infoTelnet connection to Yeelight established
and they have started dropping again..
dev:46 2019-08-03 07:10:38.150 pm error Telnet connection dropped...
dev:47 2019-08-03 07:10:38.188 pm error Telnet connection dropped...
and back again.. Please help @mike.maxwell
dev:47 2019-08-03 07:12:38.163 pm debug heartbeat- message sent...
dev:47 2019-08-03 07:12:38.162 pm debug ts- ct:1564823558161, lhb: 1564823439228, age: 118933
dev:47 2019-08-03 07:12:38.160 pm debug getReTry- reTryCount:0
*blank stare at screen...
[dev:41](http://192.168.1.140/logs#dev41)2019-08-03 07:14:38.039 pm [debug](http://192.168.1.140/device/edit/41)getReTry- reTryCount:1
[dev:41](http://192.168.1.140/logs#dev41)2019-08-03 07:14:38.038 pm [debug](http://192.168.1.140/device/edit/41)ts- ct:1564823678036, lhb: 1564823331896, age: 346140
[dev:41](http://192.168.1.140/logs#dev41)2019-08-03 07:14:38.037 pm [debug](http://192.168.1.140/device/edit/41)getReTry- reTryCount:0
[dev:41](http://192.168.1.140/logs#dev41)2019-08-03 07:14:41.046 pm [error](http://192.168.1.140/device/edit/41)Telnet connect failed, trying again in 120 seconds...
[dev:41](http://192.168.1.140/logs#dev41)2019-08-03 07:14:41.045 pm [debug](http://192.168.1.140/device/edit/41)getReTry- reTryCount:2
[dev:41](http://192.168.1.140/logs#dev41)2019-08-03 07:14:41.043 pm [debug](http://192.168.1.140/device/edit/41)initialize error: No route to host (Host unreachable)
an explanation, but probably not an answer
So my weekend was eventful.
I got a UPS on friday, super excited to get home, link it with my NAS and had an app for HE to grab the info from the NAS and create a nice little power safe setup for my shiny devices.
Woke up saturday, everything running normally, left the house at 8am.
got home after lunch to find the poor little HE going through a world of database issues.
ontop of that, all my yeelights (only) were dropping telnets and freaking out. A power cycle didnt help any of the situatiโฆ
