Hi all - I was looking through my logs and noticed this error repeating itself over and over. Any idea what this is? I can't even tell which app/process it is!
groovy.lang.MissingMethodException: No signature of method: org.apache.http.conn.HttpHostConnectException.getResponse() is applicable for argument types: () values: [] Possible solutions: getMessage() on line 1346 (updateDevices)
EDIT: Oh, I at least figured out that it's my BOND home integration app by filtering the log.
Probably get more help if you ask in the Bond thread.
One common problem - make sure the IP address of your Bond bridge entered in the Bond integration is correct - if you rebooted your Bond Bridge or rebooted your router, the IP of your Bond Bridge may have changed.
Good point. When I first posted this I hadn't figured out that it was the Bond integration. Will do, assuming that your advice isn't exactly what I needed. That makes a lot of sense given that I had the Bond bridge disconnected for a good while after I first set it up. I'll get it on a static IP and then reintegrate.
