Good afternoon,
Ive posted on this a few times but no resolution.
I have 2 hubs
c5, 192.168.1.182
Mac address 34:E1:D1:80:07:AD
a C7 i set up a week ago to get some rules working before transferring to a fruend
C7. 192.168.1.70
Mac Address 34:E1:D1:81:64:33
When i was setting it up i was having intermittent issues seeing the hub on my phone from portal.hubiat.com
I posted last week and some of the suggestions that ive tried included
Portal.hubitat.com
https://portal.hubitat.com/findmyhub
http://[hub IP address]:8081....with my ip address
Advanced discovery with the mac address and advanced discovery with the hubs IP address.
I also tried another suggestion that i was given - switching from Auto network settings to fixed 100......
None of the above helped. Doesnt show up on my phone.
Another suggestion was to assign a static IP.
I logged on to my router. Assigned the same IP as it had....nothing.
I logged on the router again - assigned a different IP...rebooted my hub. I can find the hub on my computer...but not on my phone
Both hubs are connected back to the same switch ( all ethernet cables in the house route back to a 24 port switch. I know they are on the same network as i can get to them both on my computer.
Ive tried 2 different phones and a tablet that doesn't have cell coverage.
IN all cases i can only see my C5
The only thing that i can see is different is that my C5 is registered to me..the C7 doesnt appear to be registered.
When i go to the landing page "Welcome to your Elevated Home" there is an option for register. When i press that and then continue...it just takes me back to the landing page "Welcome to your elevated hub"
When i go to my.hubitat.com i can only see the C5
Not sure if this has anything to do with the connectivity issue....hard to believe as the tablet should be no different form my computer and i can see the C7 from my computer but not my hub.
I honestly don't mind factory resetting the hub if it helps. I only have a few devices connected.
I can post any pics necessary to help.
Appreciate any thoughts.
Mac
