I am starting a new thread / hopefully opening a support ticket on my hubitat c8 pro.
. After working ok Tuesday - Wed morning initially once again z-wave performance gone / non existant. Definitely good mesh, no ghosts, I ran z-wave logging last night I am about to feed that into AI. Hub light is on and green, but the hub / app itself was VERY slow / non responsive about an hour ago - but now the hub is accessible again (but z-wave still crappy).
AI summarized my z-wave logs as this …
Overall, the vast majority of your mesh looks beautifully healthy, but there are two notable entries to look at closely:
1. The Dynamic Routed Device: dev:712 (Highly Active) (zooz z-wave motion sensor)
On pages 1, 3, and 5, dev:712 is quite active. Looking closely at its routes, it is consistently bouncing between different multi-hop paths to get back to the hub:
It frequently routes via
repeaters: [0x3e, 0x15]at 100 kbps with a103mstransmission time. -
It occasionally drops down to
speed: 40 kbpsviarepeaters: [0x3e]with a144mstransmission time. -
Its entries show
routeChanged: truequite a few times.
What this means: routeChanged: true isn't a failure—it means the mesh is actively doing its job. Because dev:712 is likely a bit further away from the hub (indicated by it needing 1 or 2 repeaters), the Z-Wave stack is dynamically shifting paths to find the most efficient route. Its transmission times (around 100ms–140ms) are completely fine for a routed device, so as long as it isn't lagging in real-world performance, its behavior is normal and healthy.
2. The Slow Direct Device: dev:267 (zooz zen 04 plug -aways away from hub)
On pages 2 and 4, dev:267 shows up regularly.
It is hitting the hub with
repeaters: None(direct route). -
However, it registers a latency of
1021msto1022msand listsspeed: Unknown.
What this means: When a direct device takes over a full second to communicate and shows an unknown link speed, it usually means the hub is having to re-transmit the packet multiple times before it finally gets an acknowledgment (ACK).
If it's a battery-powered sensor: It might be sleeping right as a message finishes, or it's an older Z-Wave non-Plus device.
If it's a main-powered switch/plug: It might be positioned right on the physical fringe of your hub's direct RF range, causing packet drops that require retries.
Summary Checklist
dev:633Removal Success: The network is completely clear of the rapid-fire per-second clutter. Bandwidth is wide open. -
dev:712: Standard, healthy mesh routing behavior. Nothing to worry about. -
dev:267: This is the only device experiencing notable latency (1 second delay). If you notice this specific device ever being sluggish to respond on your dashboard, you might want to look into its placement or see if a nearby line-powered Z-Wave Plus device can act as a better repeating neighbor for it down the road.
Everything else in these logs—like dev:912, dev:62, and dev:1094—is operating flawlessly at a blazing fast 1ms direct speed!
Notthing jumps out to me in the logs.
Wednesday, I redeployed my older c7 hub. I had to add a few devices to it that I had put on the c8 pro since May … minor stuff.
The c7 is performing flawlessly …. but that is without the addition of that yale door lock and the 4 smartwings shades.
My plan is to add the yale lock tomorrow and then test for 3-4 days. If it looks good - I will do a fresh migration to the C8 Pro after factory resetting it. Then run IT for at least 3-5 days and see.
For Rick and others - I want this to remain open as I still feel there is SOMETHING wrong with that c8 pro hub. A reset may cure it - we shall see.
