This menu option seems gone, replaced by a request for payment to get local access to the hub. Can this possibly be true or am I missing something?
Sounds like you weren't on your local network (phone may have chosen the data signal instead of the wifi if you were home).
YES! I think that’s it. It’s back to normal now but I didn’t do anything. Thanks.
I too had this issue and I was on the local network. My wifi was connected, and I could manually browse to the hub in Safari via IP address.
Force closing and reopening the Hubitat app had no effect, I still only saw the option to [Purchase remote admin] where the [Connect to hub] option normally is. I could even go to the [Registered hubs] option and use the [Connect to hub] option from there (proving again that I was connected to local network where Hub is).
I restarted the phone and it then showed as expected.
I do think that there is a missing check or some buggy logic for this button switching between [Purchase remote admin] and [Connect to hub].
